#1 | |
![]() Join Date: Feb 2003
Trader Rating: (289)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 289 reviews
Updated March 14 2012 3:15am
Located:Oceanside and Orange County I now have 2 more part out cars, white pignose hatch no motor trans, no holes in hatch, primer green hatch pignose WTB One Piece Driveshaft s13 non ABS WTB Hicas Rack 300zx Brand New Rear Brembo Rotors $95 Freshly Machined 300zx Rear Brembo Rotors $40 ![]() Special Ordered these pads, and went with a full race pad for the track instead. Endless SS-Y 300zx/STI Rear Brake Pads Brand New(Unopened) $115obo ![]() Project Mu B-Force 300zx Front(26mm or 30mm) Used, mostly freeway 3000-5000 miles? $85 ![]() Aluminum one piece driveshaftshop drive shaft almost brand new s13 w/ abs $350obo S14 Peak Performance Brand New Front 5 Lug Hubs Comes w/ Studs and NTN Japanese Bearings $200 ![]() S14 Manual Seat Belts Front and Rear Set $75 ![]() s13 Manual Black Door Panels $80 s13 Power Black Door Panels $80 ![]() ![]() s13 Clean Grey Glove Box with Bracket $35 ![]() S13 5 Speed Driveshaft $80 S13 Welded Diff $80 S14 Brembo 5 Lug Front Rotors $80 ![]() S13 Radio Din Pocket w/ Radio Brackets $25 S13 Clean Grey Glove Box with Bracket (Handle is fine, picture is distorted) $35 S13 Ash Tray $15 S13 Hatch Moonroof Latch Not Broken $20 S13 Gas Latch Trim (slightly faded) $5 S13 JDM Cluster(I read that it will work with DOHC harness? I wonder if SOHC and DOHC harness r the same) $90 S13 DOHC Cluster(Harness extra)$75 S13 Passenger Window Switch $25 Power Window Amp $25 ![]() s13 Passenger Window Switchs Driver(No buttons) and Passenger $50 ![]() S13 Dome Light $10 ![]() Coupe Third Brake Light For Non Spoiler Trunk Lid $30 ![]() ![]() ![]() 1991 Coupe Body Harness From Rear to Dash Manual Windows, No sunroof $100obo ![]() KA Fan Shroud $30 S13 Left Kick Panel $10 S13 Steering Wheel Undertray Trim Piece $15 S13 Door Jam Interior Floor Trim Pieces $15 S13 Headliner Trim Piece $10 S13 Ash Try w/ Good Spring $15 S13 Steering Wheel Cover Trim pieces $15 S13 Bottom Half Steering Wheel Cover Trim $5 Clean S13 Radio Brackets w/ Din and 4 Radio Screws $25 ![]() HKS EVC EZ Boost Controller(Missing harness, but might find it) $120 ![]() S13 Coupe Black A Pillar Trims $20 S13 Coupe Black C Panel Trim(Arm Rest Pieces) $20 S13 Coupe Black A Pillar Trims $20 S13 Hatch Black A Pillar Trims $20 S13 Hatch Black B Pillar Trims $25 S13 Hatch Black C Panel Trims(Arm Rest Pieces) $20 ![]() Maroon manual passenger door, perfect, with harness and plug, manual side view mirror optional, comes with speaker box $65 ![]() Black manual passenger door, clean, with harness and plug $65 ![]() S13 Hood Hinge right side $5 S13 Trunk Hinges w/ Spring Rods $15 S13 DOHC Cams 248/240 (Used for upgrading DOHC cams for better power) $50each pair ![]() S13 Black Gas Cap Cover $20 ![]() S13 Grey Headliner(From Coupe, Not sure if that is relevant) $30 ![]() S13 Guage Cluster Bezel $15 S13 Guage Cluster Clear Plastic Cover $7 ![]() Some KA brackets $5 Modified Sr20det Throttle Cable Bracket(For greddy style intake manifold) $10 Side View Mirror Lenses $12 Fuel Pump Wiring Cover Piece $5 New s13 NSK OE Quality Wheel Bearing $50obo ($60+Tax new) Headlight Black Trim Covers $20 a pair Auto Transmission Crossmember $15 DOHC Cluster Harness $20 Clean Pink Fuse Box Cover Lids $10 each ![]() Coupe Rear Bumper Support $30 Coupe Rear Bumper Foam $10 ![]() Make some offers ![]() ![]() ![]() Exedy Stage 2 Clutch Kit Used(Disc probably needs to be repadded, but I am not sure)$50obo Sr20det Coolant Temperature Sub Harness w/ Broken Clip $10 Rear Parking Lights $15 Sr20det Coolant Temperature Sub Harness SOLD Nissan Oem Jack w/ lug wrench(otherwise ill keep it) $40obo Rear Trunk Plugs $3 for big one $2 for little ones ![]() Stock SR20DET Intake Manifold Comes with whatever in picture, No IACV, No Throttle Body $40 Stock s13 Coupe Automatic Brown Seat Belt System w/ Ecu Rails, Belts minus driver belt, Ecu $30 Regular Straight 2" Stock Hotpipe SR $10 Stock SR20DET Thermostat $5 Front s13 240sx Stock 24mm Sway Bar $10 More random things, good exhaust hanger and some new and used gaskets, one gasket has a tear. Most of these things I list just in case someone needs it. ![]() ![]()
![]() Quote:
Couple things..... The 3" exaust gaskets and if youl sell the pasenger side mirror off the door. mine is missing the glass but im not sure if one of the ones you have will completely cover whats missing on mine. how much shipped to florida.
#5 | ||||
I am not sure how many miles are on it i cant remember. it was pulled out because i installed a lightened flywheel and clutch combo that were mated together when i had my tranny out. Here are pics: ![]() ![]() ![]() Quote:
large flat rate 40 shipped
![]() Quote:
Yes door can be arranged for pick up in oc with mirror. There are no dents on it either.
![]() Quote:
#9 | |
Im not sure what code it is. But this is maroon off a 91 coupe.
![]() Quote:
#11 | |
Yeah it looks like they are. Ill do 60 shipped.
![]() Quote:
#13 | |
I cant remember exactly the numbers, But I know I had measured and it was 1mm thicker or more than the minimum, the measurement was in between brand new and minimum. 1 time turned. There is nothing wrong with them, they have meat left, and they were turned by professionals.
The new rotors are 5 lug new in box. They are still cheaper than buying retail so you can afford to drill them if needed. I can do 105 shipped on the new
![]() Quote:
#17 | ||
pm'ed
I can do 40 shipped for the brake light, but I cant ship you the headliner man. It would just be way to expensive.
![]() Quote:
I will get back to you. Also one of the black passenger side door handles not the plastic piece that goes into the door panel.
#19 | |
no sorry i cant do 40 shipped for both. if i have to ship the headliner trim and the third brake light it would change the box completely and I would need to get you a whole new estimate. I would assume shipping those 2 items together is going to make shipping annoying and expensive. if i shipped them seperately it might be cheaper , not sure until i get an estimate.
![]() Quote:
#20 | |
#21 | |
50 shipped cuz i didnt really want to take parts off the door.
![]() Quote:
#22 | |
Alright so i have 2 almost complete hatchbacks now one is white and one is primer green. im gonna have to start new threads coming soon. but if someone reads this before then hit me up for parts i have way tooooo many right now. need to get them moving and make a little money to fix my strut tower.
white one has no holes in hatch. primer green has perfect fenders pignose white fenders are not bad either but have some ripples or dents dings here and there, not bad ones. I will get this shit going asap
![]() Quote:
#24 | |
ok i typed a long response a few times on my phone and it deleted both times, so ill respond through my computer this time.
I added and am adding many many new parts, I tripled my collection at this point and have 2-3 of everything. I have 3 sets of fenders right now, I believe 2 sets are pignose and of the third set driver is pignose and passenger is chuki. The price is depending on the condition of each set, the primer green pignose fenders are perfect condition The white pignose fenders are not perfect And the pignose driver and chuki passenger are both in excellent condition with minor issues. I have been hit up for pictures multiple times but i was away for work over the weekend and am at work now until later today. I apologize to everyone who is waiting on me, for some reason there is not enough time in the day.I am working on getting all questions answered and all pics taken. I can answer any and all questions just give me some time to catch up . thanks :P
![]() Quote:
| 5 lug hubs, brembo, endless, part out coupe, project mu |
