![]() Join Date: Feb 2012
I have a crap ton of extra parts that have been sitting in my garage that I have no use for. Tax return time is here, time to move this stuff and make some space.
Prices do not include shipping/paypal fees unless noted otherwise. Reasonable offers considered, others ignored. Most of this stuff was used on my S14 KA-T, I've changed the setup and have no use for this stuff. SOLD!!! S13 MT RS Enthalpy ECU tuned for T25/T28, 370 Injectors, N60 MAF. I switched to a JWT with a Z32 MAF (also an S14 ECU) for emissions reasons. $250.00 for ECU SOLD!!!, with N60 MAF and 370cc Injectors (sonic cleaned, tested, new o-rings) for $400 shipped. ![]() ![]() N60 MAF Sensor $50.00 Has a broken tab, can be JB Welded if necessary. If its really a deal breaker, I have another one that isn't broken, and I can probably source a pigtail if you really need one. ![]() ![]() ![]() S13 to S14 KA24DE Conversion Harness - $100.00 Shipped (Not Pictured) This was used in my S14 to use an S13 ECU. Wiring Specialties sells them for about $140.00 before shipping. Powered By Max Tension Rods for S14 - $190.00 Shipped Perfectly straight, car isn't used for drifting. Johnny Fraz Tension Rod Brace - $90.00 Replaced with a Nismo Power Brace, so this has got to go. I cleaned up and replaced some of the hardware. This requires modification to your existing tension rod brackets. ![]() DIF Turbo Clocking Adapters - $75.00 Shipped All hardware included. Bought this because I thought I'd need it when upgrading my turbo. Hardware was mounted, but car was never actually started with it installed. Turns out it was unnecessary. My loss, your gain! ![]() Megan Racing Turbo Outlet Pipe - $100.00 Shipped Sold the turbo manifold this went with, guy didn't want it. Bolts onto T25/T28. No additional hardware included. ![]() Circuit Sports (I believe) Catch Can - $20.00 Shipped What you see is what you get....well, except for that little bit of IC piping. That stays. I think there are two clamps at the top of the can, but that's all I have for it. I don't know anything else about this except the previous owner of my car had it installed poorly and I don't need it. ![]() Trust Front Mount Intercooler - $75.00 I bought this to replace the CX Racing FMIC that is the size of my penis. I don't know how the dents came to be, guy I bought it from had a car that was hella low. Probably there. I took what pictures of the damage I could. There is a little dab of JB Weld, but unit still holds pressure perfectly fine, tested with compressor (pictured) ![]() ![]() And this side is perfectly fine. I don't know, man. ![]() CX Racing Front Mount Intercooler - $75.00 This fucker is huge. (See above comment!) Came on my car when I bought it, includes one bolt and the rusty homemade mounting bracket. ![]() Slight bending from where it hit one of those damned parking lot curb blocks. The struggle is real. I'm sure you can imagine the amount of swearing involved when that noise was heard. ![]() ![]() T25 Turbo Inlet Pipe - $30.00 Shipped I've got two. Don't know why I bought a second, but its a thing I did. Take them off my hands. Its in the picture, the little pipe that looks out of place. Hopefully you know what you're getting with this. Front Mount Intercooler Piping - $100.00 Two Sets here. One set has heat shrink wrap and a flange for a Greddy BOV (BOV not included) as well as couplers and most of the clamps. I think its missing like two that broke during removal. It also has a cut in the hot pipe where an additional coupler was placed for a nipple in a coupler. Seals up fine, just wanted to mention it. The hot pipe side was also crushed a bit to fit in the stock hole. There is an additional spacer in the coupler so no air leaks. (see the photo) The other set is perfectly fine, no issues...but no additional flanges, couplers, or clamps ether. First come first served on choice of IC piping. The one set is the four pipes on the left, the other is on the right...and top-ish. If you're going to be a dick about it and need extra pictures, fine. But its pretty standard stuff, dude. ![]() See? Not as bad as you thought. ![]() Other items not pictured: Peak Performance Tie Rod Ends - $20.00 One is broken off from being too tight, other is perfectly fine. Source a second and you're on your way. If you think you can repair the other one, be my guest. SOLD!! Powered by Max Traction Rods (S14) - $175.00 SOLD!! Going back to stock. Car doesn't drift, I really don't need them. Still on the car, if you're serious about purchasing them, I'll remove them. SOLD!! SPL Parts Rear Toe Arms (S14) - $200.00 SOLD!! Same deal, I'm not baller enough to keep them, going for something less race-car-y. Also still on the car. If you're man enough to handle them, pick these up. Pics were requested, so I'll share them with everybody. ![]() ![]() ![]() ![]() B&N Short Shifter Kit (S14) - $200.00 Shipped Forgot about this when taking pictures. Its in the back seat of the car. I need to finance one of those baller C's shifters that I keep seeing. #/f/showthread.php?t...=C%27s+shifter Oh hell yeah. I can obviously combine items to save on shipping costs. And because I'm an actual, functioning adult, I have the ability to ship items. Unlike all those people in SoCal. ![]() Like I said before, reasonable offers considered. Give me a reason to lower my prices, being broke isn't a good reason. Tis the season to buy extra stuff because the government took too much money from you. (s)Last edited by johnnysombrero; 04-25-2016 at 04:59 PM.. Reason: Updated list with sold items |
Haha, thanks man. Us East Coasters have to stick together. I hope Sam the Dog is okay, hope you all are still talking. #samandmax
Texted. I don't understand the question. The FMIC piping is all 3 inch except for the hot pipe where it expands from 2.5" to 3". Or are you talking about my lovely 3" exhaust that isn't pictured here or for sale? The Megan turbo outlet pipe is also 3". What are you looking for specifically? |
#10 | ||
Yup, I took them off the car today. They're ready to ship out, just show me the money. |
Do you have Hotwire piping? I just need the hot side piping if your willing to part out? I just need the piping from the intercooler to the turbo on the hotside
| fmic, intercooler, intercooler piping fmic, suspension |
