![]() Join Date: Nov 2004
Coil Pack Questions
Has anyone run P2M coils on a high boost/high hp motor? If so, did they hold up fine? Next question is what coil pack options are out there, that will still allow me to run my coil pack cover plate? From what I've heard, the VQ coil packs should fit under the cover. Can anyone confirm this? Any other suggestions?
Can't confirm on fitment, although R35/Yaris look really close from images I've seen, but Motive just released an awesome coilpack comparison video that might help with your decision.
https://www.youtube.com/watch?v=4d3nrBZjYKA |
i like the P2M products and theirs has a good warranty, if looking at other manufacturers GM coils have been great, especially those from the Tahoes with the heat sinc on top
I ended up going with the Platinum kit. Pricey, but it comes with everything needed, including a mounting plate, as well as custom stalks designed for the SR.
GM coils are not as good as everyone says they are. In addition, they are simply bulky and a pain to mount and just plain do not perform.
R35 coil packs are the incorrect length. I bought my Taarks R35 GTR conversion kit as it was the cheapest and easiest solution. G37 coil packs are almost identical to the R35. The only variance is boot length and an internal probe (the GTR coil pack has it, if my memory serves me correct, the G37 does not). G37 should just about fit on the S13/S14/S15. |
