It's glued in. So you'd have to have a good razor-blade tool to cut it out, then have the proper adhesive to glue the new one back in.
If you've replaced a windshield, then this could be an easy DIY, if not it might be better to have a glass shop do it. |
The windows have some plastic guide pins glued on them from the factory also. Unless they were cut when the windows were removed. So lining them should be that hard.. just lined the pin with the hole in the body and adjust a bit and your golden
