For Sale Items Post items for sale here. ABSOLUTELY NO COMMERCIAL SALES. |
02-23-2015, 10:37 PM | #1 |
Trader Rating: (106)
Feedback Score: 106 reviews
S13 SOHC parts and complete engine
2 S13 SOHC distributors
These are good working condition S13 SOHC distributors. Both came out of running cars with no issues. $30ea S13 SOHC alternator This is a good working condition alternator for S13 SOHC. It operated perfectly upon removal, no charging light. $30 KA24E fuel injectors These are 7 KA24E (sohc) fuel injectors. All 7 test good electrically and came off good running engines. $20ea NEW set of belts for SOHC KA This is a set of all 3 BRAND NEW, NAME BRAND belts for a SOHC KA. I will not separate the set. SOLD! S13 SOHC KA complete engine This is a complete SOHC ka, that I pulled running 2 weeks ago with 162k on it. I decided to swap it because it needs timing chain guides and I had a dualcam sitting around. Included with the engine is a COMPLETE timing set pulled off another engine that was re-built. The timing set includes the chain, guides, tensioner, and both gears. You will also need to get an igniter to make then engine run as I used it on the dualcam I swapped in. Other than that it simply needs to be re-sealed and hoses and stuff, like every other singlecam out there. Included with the engine are a complete stock intake, power steering lines w/resovoir, spare power steering pump (one on the engine is leaking), throttle cable, wiring harness, and 2 stock ecu's. Not included with the engine are ANY 5-speed parts, downpipe, starter, radiator/fan shroud, and the A/C compressor. -LONGBLOCK SOLD SOHC power steering tensioner This is a good condition SOHC power steering belt tensioner. The pulley is undamaged, the bearing is nice and smooth, and the adjuster works perfectly. SOLD! SOHC alternator/water pump tensioner This is the SOHC alternator/water pump belt tensioner. I see these damaged or missing parts all the time, so I figured it might be useful to someone out there. It's in good shape, no issues whatsoever. $10 SOHC water pump pulley This is a good condition SOHC water pump pulley, no damage. $10 SOHC fan/clutch This is a SOHC complete clutch fan. The fan blades have very minimal cracking and the clutch is still good. It's just a little dirty. $25 SOHC exhaust mani w/heatshield This is a good condition SOHC exhaust mani with the heat shield. No cracks or damage of any kind and the mani does not have any bolts broken off in it or broken studs. $25 SOHC distributor cover This is the cover that goes over the distributor on a SOHC KA. You hardly ever see these still on the cars and it adds a bit of a cleaner look to the plug wires. $10 SOHC crank pulley Good condition, no damage, not rusty. $20 SOHC ignition coil This is a SOHC ignition coil with the bracket and WITHOUT the igniter. Came off a running/driving car, no issues. $10 SOHC MAF sensor This is a good, working SOHC MAF sensor with a 3 pin connector. Came off a 100% running/driving car, 100% FOR SURE good. I will clean the MAF element before pick-up/shipping with MAF sensor cleaner. PENDING SALE 2 SOHC M/T ECU's This is an ecu for SOHC, M/T, CA emissions. I have 2 of these. 100% for sure good, came off running cars. $25 One SOLD, One Left SOHC plug wire set This is a used, but recently replaced, complete set of SOHC plug wires. The wires are good quality, no loose boots, no pulled out connectors. $10 SOHC intake air temp sensor This is a good working condition SOHC air temp sensor. It mounts in the airbox on SOHC cars. $10 SOHC complete intake mani/sensors This is a complete intake mani assembly with all the sensors. I am parting this out so PM me with what you need and we can work out a price. $offer$ Last edited by racepar1; 03-25-2015 at 10:43 PM.. |
03-05-2015, 08:03 PM | #11 | |
GM2 (SW/AW)
I need a non cracked valve cover. Pretty bad.
If you'd sell the entire head, shoot me prices on that also. 34234
KA-T for life! Current for sale advertisement |
03-05-2015, 09:08 PM | #13 | |
Yes it is...
If someone wants it I will, the ONLY thing missing at this point is the engine wiring harness. |
