#31 |
Nice looking car.. its got good potential for a clean paint job... haha
ps, im going nuts without my z32 so hurry with the q45 diffs and j30 axles! lol
**WTB Q45 diff, pm me a link if you know where I can find one please!** |
#34 |
![]() Join Date: May 2008
![]() ![]() ![]() Feedback Score: 1 reviews
Again I'm not happy with the way the engine sits I'm currently redesigning the mounts to pull the motor back 2 inches and up 1 inch, also going to call in some reinforcements and do a rear sump oil pan.
#41 |
sooo update. motor is mounted. FINALLY, this was a mission lol.
new mounts, motors sits back 2 inches and up 1 inch, custom rear sump oil pan is being Researched and Developed. I put a new unmodified crossmember in and because the motor sits so far back I cannot use to factory front sump, this is good anyway because i really did not like to have to do two extremes, I either wanted a modded pan or a modded k member, I'm happy this way because i dont need to mod the k member in any way and I get to have a sweet rear sump. I didnt like the front sump either cause in case of off roadage, thats the first to go. front end is back together with more angle , more cut knuckles and PBM inner tie rods.lowrider custom seat brackets bought a new toy to help w the headers Sourced a couple accessories, I can honestly say the car is half way done, Most of the stuff is together, all that is left is to finish up the headers, the mid pipe of the exhaust, couple brackets, the engine wiring, and bolt up the interior. I'm starting to get excited!!
#42 |
FINALLY done with the headers, actually went alot faster than last time, guess just more experienced. Well I'm back to where I was a couple months ago lol, motors relocated with new mounts and headers are done, got some other stuff going on, next major thing is wiring it up and getting the rest of the little things. Getting Warmer!
#47 |
Small stuff happeneing.
Modified alternator bracket, moved it down, basically put it where the ac comp was. cut off the end of the coolant pipe cause it stuck up high and rewelded the beaded end on so hoses stay on. other project, bye bye t tops! and center panel.
#50 |
mini update.
Passenger headers is mounted and pass midpipe is tacked up, waiting on a oil adaptor to mount drive header and driver midpipe, then some wiring and plumbing!! Went to the yard and scored everything I needed even found a sweet key from the q45 I tore apart Also am relocating the ignition switch to the center panel I made. why not just get a sweet gay button and switches? because I like my titanium key and I wanna keep it. My friend had a parts car so I ripped the rear quarters out of it for spare parts. Then I cut the whole car in half. If you've never done this, this is definetly something to do in life, so much fun. thats all for now.
#53 |
Put on some finishing touches anndd started it up!!!
key switch relocation midpipes wiring bye bye ttops window sticker http://www.youtube.com/watch?v=xos2MnVxe-c[/url] http://www.youtube.com/watch?v=-7ApLtdgGhg[/url]
#59 |
![]() Join Date: Jan 2011
Z32 are just mean when modded!
cross paths with a slammed Z32 the other day...damn near broke ma neck |
