Parts Shop MAX ~Multilink, Steering & Subframe Parts~ IN STOCK Live quotes in thread!
Huge shipment just arrived, Zilvia exclusive - FREE Priority Shipping - for a limited time on Coilovers or any other purchase of $1000 from Parts Shop MAX! Just use the code Zilvia1 in the shopping cart then click the apply coupon button.
*Ends 11-1-2010 *Lower 48 states only PURCHASES AND SHIPPING QUOTES DIRECTLY FROM THIS THREAD! SIMPLY CLICK THE BLUE ADD TO CART LINK VIEW CART ![]() Our third and fourth generation arms and rods are stronger than ever. MAX multilink features more clearance for lowered cars than any other brand, as well as the adjustability you need to dial in your cars maximum performance. They let you set your personal preferences on characteristics like turn in, grip, tire wear and drift initiation. All of the MAX multilink parts are equipped with premium Japanese design pillowball joints and original forged rod ends that eliminate OEM rubber bushings for a precision, predictable, tactile driving experience. The quality is on par with the best the world has to offer and the unique design features make them an unbeatable value. The MAX multilink can be complimented by using or famous MAX coilovers, Subframe Collars or Subframe Solid Risers, Super Steering Angle Knuckles, and IF tie rods for a perfectly tuned drift spec suspension setup. RUCA $200+sh CLICK HERE TO ADD TO CART FOR AN INSTANT QUOTE OR TO ORDER ONLINE In stock NOW! TOE ROD $200+sh CLICK HERE TO ADD TO CART FOR AN INSTANT QUOTE OR TO ORDER ONLINE In stock NOW! TRACTION ROD $180+sh CLICK HERE TO ADD TO CART FOR AN INSTANT QUOTE OR TO ORDER ONLINE In stock NOW! TENSION ROD $200+sh CLICK HERE TO ADD TO CART FOR AN INSTANT QUOTE OR TO ORDER ONLINE In stock NOW! SUBFRAME COLLARS $50+sh CLICK HERE TO ADD TO CART FOR AN INSTANT QUOTE OR TO ORDER ONLINE In stock NOW! SUBFRAME SOLID RISERS $100+sh CLICK HERE TO ADD TO CART FOR AN INSTANT QUOTE OR TO ORDER ONLINE In stock NOW! MAX S13 Competition Coilovers $1000+sh CLICK HERE TO ADD TO CART FOR AN INSTANT QUOTE OR TO ORDER ONLINEIn stock NOW! MAX S14 Competition Coilovers $1000+sh CLICK HERE TO ADD TO CART FOR AN INSTANT QUOTE OR TO ORDER ONLINEIn stock NOW! SUPER ANGLE KIT PARTS ONLY $250 with free* shipping (*must be the only thing in the cart) CLICK HERE TO ADD TO CART FOR AN INSTANT QUOTE OR TO ORDER ONLINE In stock NOW! SUPER ANGLE KIT PARTS AND LABOR $400 + return shiping CLICK HERE TO ADD TO CART FOR AN INSTANT QUOTE OR TO ORDER ONLINE In stock NOW! MAX R.U.C.A. 4 (Rear Upper Control Arm) for camber adjustment on Super low S chassis cars ~NEW - larger bend radius to clear all types of coilovers ~100% TIG welded ~3mm/.120 wall thick DOM tube ~Single consistant bend keeps stress evenly distributed ~PTFE Teflon lined service free spherical bearings with dust covers ~50mm 1 piece forged rod end ~Powdercoat orange paint and Gold chrome finish on adjuster and rod end ~Angle union between adjuster tube and arm helps clear the chassis on lowered cars ~Upswept arm helps clear Axle boot on lowered cars ~Arm length maintains around -1 degree of camber on lowered cars with minimum adjuster thread exposure *If your car currently has no adjustable multilink you must install RUCA and TOE together to adjust your rear alignment properly because in the S chassis when you change the camber it effects the toe setting. RUCA $200+sh CLICK HERE TO ADD TO CART FOR AN INSTANT QUOTE OR TO ORDER ONLINE In stock NOW! ![]() ![]() ![]() ![]() MAX Toe Rod ~Double TIG welded fork bracket ~31mm 6061 CNC amuminum adjuster tube is located far away from the subframe bracket for ease of adjustment ~23mm solid steel bend clears the subframe on extremely low cars ~PTFE Teflon lined service free spherical bearings with dust covers ~40mm TIG welded rod end ~Orange and gold aluminum hard anodizing and Gold chrome steel finish *If your car currently has no adjustable multilink you must install RUCA and TOE together to adjust your rear alignment properly because in the S chassis when you change the camber it effects the toe setting. TOE ROD $200+sh CLICK HERE TO ADD TO CART FOR AN INSTANT QUOTE OR TO ORDER ONLINE In stock NOW! ![]() ![]() MAX Traction Rod ~Double TIG welded fork bracket ~31mm 6061 CNC amuminum adjuster tube ~23mm solid steel bend clears the subframe on extremely low cars ~PTFE Teflon lined service free spherical bearings with dust covers ~40mm TIG welded rod end for S13 ~44mm 1 piece billet aluminum rod end for S14 ~Orange and gold aluminum hard anodizing and Gold chrome steel finish ~Increase traction by shortening this rod 1cm from stock length on higher cars or lengthen this rod for super low cars for correct geometry. *OK to install independant from any other suspension part. *27mm short and skinny wrench is recomended for ease of installation in cramped rod end/subframe area. We sell a custom wrench for $5. TRACTION ROD $180+sh CLICK HERE TO ADD TO CART FOR AN INSTANT QUOTE OR TO ORDER ONLINE In stock NOW! ![]() ![]() MAX Tension rod ~These come with the same 1pc. forged steel end joint like our third generation RUCA. ~They have the yellow silicone dust covers and the new steel ball joint spacers as well. ~Steel locking nuts for the length adjustment are in place of aluminum from the previous model ~The anodized 6061 aluminum tube and end bracket are carried over to the new model. ~Hardware for the LCA is included. *OK to install independant from any other suspension part. *More caster creates a self steer feeling while drifing and less caster is good for cars equipped with our super angle steering knuckles. TENSION ROD $200+sh CLICK HERE TO ADD TO CART FOR AN INSTANT QUOTE OR TO ORDER ONLINE In stock NOW! ![]() ![]() ![]() MAX Subframe Collars ~CNC 6061 Aluminum ~Stiffens OEM bushing to eliminate wheel hop after clutch kick ~C shaped upper collars for easy installation ~Gold hard annodized finish *Can be installed independant of any other parts SUBFRAME COLLARS $50+sh CLICK HERE TO ADD TO CART FOR AN INSTANT QUOTE OR TO ORDER ONLINE In stock NOW! ![]() MAX Subframe Solid Riser ~Completely replaces OEM Subframe Bushing ~Raises Subframe a half inch for lowered suspension geometry correction ~Makes more clearance to raise exhaust ~Slip fit, epoxy-it-in installation (no press needed) ~CNC 6061 Aluminum ~Gold hard annodized finish *Made specifically for low ride height vehicles to help fix roll center problem. *Please see our products forum for OEM bushing removal instructions *You must bend the E-brake cable bracket to reroute cable so it does not rub the driveshaft. MAX Subframe Solid Riser $100+sh CLICK HERE TO ADD TO CART FOR AN INSTANT QUOTE OR TO ORDER ONLINE In stock NOW! ![]() MAX S13 Competition Coilovers $1000+sh CLICK HERE TO ADD TO CART FOR AN INSTANT QUOTE OR TO ORDER ONLINEIn stock NOW! ![]() ![]() ![]() ![]() MAX S14 Competition Coilovers $1000+sh CLICK HERE TO ADD TO CART FOR AN INSTANT QUOTE OR TO ORDER ONLINEIn stock NOW! ![]() ![]() ![]() ![]() ![]() ![]() adjuster,pillowball ![]() bottom brackets ![]() spring, locking collars ![]() Rarely needed except when our customers crash, we stock replacement dampers $100ea+sh MAX Replacement Damper S-chassis Front CLICK HERE TO ADD TO CART FOR AN INSTANT QUOTE OR TO ORDER ONLINE MAX Replacement Damper S-chassis Rear CLICK HERE TO ADD TO CART FOR AN INSTANT QUOTE OR TO ORDER ONLINE ![]() Are your butt cheeks sore from daily driving? We sell 6KG springs to soften things a bit. MAX s chassis coilovers come with 10KG front & 8KG rear springs so if you wnat to run 8KG front, and 6KG rear, just take the 8KG off the rear and put them on the front, and then run the new 6KG pair in the back. 6kg-200mm $60/pair+sh MAX 6 KG Springs for Competition Coilovers CLICK HERE TO ADD TO CART FOR AN INSTANT QUOTE OR TO ORDER ONLINE ![]() VIEW CART Installations ![]() ![]() ![]() ![]() MAX SUPER STEERING ANGLE KIT ~Now 100% Nickel plated ~Adjustable ackerman and steering angle depending on install position (closer to the wheel is less) ~Two tie rod end holes offer options for medium or fast steering (closer to LCA is faster) ~Comes with LCA reinforcement plates ~Adjustable bump stop plates keep tie rod over centering under control ~7mm tie rod angle spacers are included. *You can install independant from any other suspension part, but longer tie rods are strongly recommended to have a safe number of threads, and to use all available settings. *release of liability required to complete sale (cut paste and email us the release located here: POWERED BY MAX: ??????????up Super Steering Angle Parts) SUPER ANGLE KIT PARTS ONLY $250 with free* shipping (*must be the only thing in the cart) CLICK HERE TO ADD TO CART FOR AN INSTANT QUOTE OR TO ORDER ONLINE In stock NOW! ![]() SUPER ANGLE KIT PARTS AND LABOR $400 CLICK HERE TO ADD TO CART FOR AN INSTANT QUOTE OR TO ORDER ONLINE In stock NOW! ![]() We can also remove the OEM parts, modify, and reinstall with toe align for $550 (local customers in San Diego only) ![]() VIEW CART Congrats to Matt on the Super Street sept. 2010 article! ![]() ![]() ![]() ![]()
How To order: You can order directly from our zilvia advertiser threads. When you add to cart, you get an instant shipping estimate, & the cart will remember all of your items as you move between forum threads and our website www.poweredbymax.net until you remove them or check out. I can also calculate estimates manually for you but the cart's estimates are way faster and more accurate. Order Inquiry: IM me your real name and paypal address. Thanks for your business! Last edited by DC Dan MAX USA; 09-21-2010 at 01:39 AM.. |
![]() Join Date: Jun 2003
Trader Rating: (129)
i didn't see it on your website, but do you make adapter spacers to run s14 subframe on s13?
if you made them, but they were also subframe risers, i would buy a set. |
No we dont make that yet
How To order: You can order directly from our zilvia advertiser threads. When you add to cart, you get an instant shipping estimate, & the cart will remember all of your items as you move between forum threads and our website www.poweredbymax.net until you remove them or check out. I can also calculate estimates manually for you but the cart's estimates are way faster and more accurate. Order Inquiry: IM me your real name and paypal address. Thanks for your business! |
![]() Join Date: Oct 2006
Got and installed the set of subframe solid bushings and they're awesome! Super easy to install and fit perfect. Definitely the best solid subframe bushings around. I used a sawzall with metal blade and cut the center section out, then made one cut through the outer metal shell and bent/tapped it out with a metal chisel and hammer, no need for burning at all. Good stuff!
No because the aluminum ends and the steel ends use different threads.
yes everything is in stock now. 4-5 days to arrive at your door.
![]() Join Date: May 2004
Trader Rating: (40)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 40 reviews
For the helm joints, what is the little hole for? these are maintenance-free/teflon-lined?
Also, for the rear toe rod, these work for both s13 and s14, correct? I know the stock ones are different between s13 and s14. Thanks!
bew bews! |
PM replied
There is a set screw in the hole that is a backup retainer for the pressed in spherical bearing. Its not a grease fitting hole. They are indeed teflon lined and maintenance free as stated in the OP. The toe rod ships with pillowball side spacers for both 13 and 14 in the box so you dont have to specify which car you have for that part.
yes sir we do
![]() Join Date: Apr 2009
Dan,
Just want to start planning my winter build purchases and finances. Can I get a quote shipped to 63017 for: Toe Arm Rear Upper Control Arm Subframe Risers Thanks! |
Just add those items to cart to get an accurate instant quote with shipping.
#17 |
All parts are in stock as it says in the OP.
Currently NO 2 month wait on the coilovers like in the past.
#20 |
replied to pm's
#22 |
lol minutes after I update our cart!
Yes sir a Zilvia exclusive - first time ever - code Zilvia1 gets FREE Priority shipping on order of $1000 until 11-1-2010 lower 48 states only
#23 |
![]() Join Date: Sep 2010
Im fairly new to 240's and I know this may sound like a dumb question but I'm buying stance gr plus coils and I want to get PBM rucas and toe rods but I don't plan on being super low like that gold s13 coupe up there but I still want to get rid of my wheel gap. There's no minimum drop to use these parts is there? Once again I'm fairly new so sorry if it's a dumb question.
#25 | |
Parts Shop MAX USA 8680 Miralani Drive 101 San Deigo, CA 92126
#27 |
![]() Join Date: May 2006
I was on the fence until you gave the Zilvia community a discount on your amazing products. You just earned my business.
I'll be placing an order in a sec! COBRA LALALALA |
#28 |
do mo arigato gozaimasu = )
#30 |
for sure, there is a new version with a light weight structure.
you can see it half way down on this page: POWERED BY MAX:
