![]() Join Date: Apr 2007
PBM Hood spacers gold.
I have a set of the Powered by max hood spacers.
i bought these when they first came out for like $40? or something like that, cause i wanted to see if they would "WORK" well it did help the heat slightly but once i went with a bigger radiator and fans the cooling issues i had on my JZ 240 went away. so i took these off they are just sitting here figured i'd see if anyone else wants them. i do not have the bolts/washer they usually come with. but i can get them if needed, or you can go to a hardware store and pick them up. ~25mm thick CNC billet aluminum ~accurate m8 center bore ~new profile for ultra light weight and strength ~more surface area against hood and latch $15 Shipped the way you see them. $20 Shipped with the bolts/washers. SOLD LOCK THIS UP SOLD LOCK THIS UP SOLD LOCK THIS UP SOLD LOCK THIS UP SOLD LOCK THIS UP
