ITS LISA'S FAULT!!!
![]() Join Date: Jun 2003
Trader Rating: (41)
JDM vs USDM S13 Driveshaft Center Bearing
Does anyone know if the OEM S13 USDM driveshaft center bearing is the same as the JDM S13 driveshaft center bearing? I just picked up a JDM drive shaft to replace my single piece aluminum DS (im not digging the single piece thing) and I want to have the center bearing replaced on the JDM shaft before installing (and also have it re-balanced if possible or needed).
