strange noise from right rear wheel.
I keep hearing this "ta ta ta ta ta" noise from right rear wheel. It has megan coilover and break pad was swapped about a month ago.
The noise is a lot louder during acceleration but is near silent when coasting at neutral. I visually checked the wheel and I haven't seen a thing protruding or out of normal. What could be the problem? |
![]() Join Date: Sep 2003
i dont understand your description of the noise. Check for a nail in your tire. wheel bearing. brake pads. ? that's all i can think of right now.
Hi |
The noise is not metallic. It sounds like a plastic. But when I checked the wheel and wheelwell area, I haven't found any thing that got in the way of the wheel or break assembly. Only thing that I could think of was the loose break pad so I reassembled the break assembly and sound keep coming.
How do I check the wheel bearing? |
#4 | |
![]() Join Date: Apr 2003
try to jiggle your wheel while it's on the ground. It shouldnt really move anywhere, but if it feels loose, that's usually a sign that your wheel bearing is no good. (facing towards the wheel, push and pull)
Team Pterodactyl SHARK ATTACK!!! LookOutDrift Quote:
![]() Join Date: Jan 2004
might just be ur tires rubbing inside rubber
96 all suspension s14 SOLD 90 s13 coupe - SOLD Currently rocking 2002 BMW M3 w/ custom suspension. ![]() ButtonWillow, CA entire circuit drift/grip event by shock drifting spot for sale. Take over my spot for $150 only. |
