Old 07-12-2011, 12:32 PM   #1
Fatboy Garage
Fatboy Garage's Avatar
Fatboy Garage is an unknown quantity at this point
Send a message via MSN to Fatboy Garage
Godspeed Projects S13/S14 5 LUG Massive Angle Kit
We are currently installing on one of our sponsor vehicles, install pictures will be up soon. As for people interested in purchasing, stay updated on the Facebook page we will announce it there first when it goes on sale! That's all for now!
Godspeed Project Facebook Page: http://facebook.com/godspeed.gsp
Share your thoughts!
Godspeed Project
2518 Continental Ave
El Monte CA 91733
P: 626-442-3988
W:godspeedproject.com
www.facebook.com/godspeedproject
Fatboy Garage is offline   Reply With Quote
Old 07-12-2011, 01:39 PM   #2
hektik13
Trader Rating: (37)
hektik13 is an unknown quantity at this point
Feedback Score: 37 reviews
you need s14
hektik13 is offline   Reply With Quote
Old 07-12-2011, 01:53 PM   #3
!Zar!
!Zar!'s Avatar
Any idea what pricing is like?
Old 07-12-2011, 02:05 PM   #4
blueshark123
blueshark123's Avatar
Trader Rating: (55)
Feedback Score: 55 reviews
im surprised this is godspeed
Old 07-12-2011, 02:35 PM   #5
Fatboy Garage
sorry I need to recall this,
is for S14 or 5 lug
Godspeed Project
El Monte CA 91733
P: 626-442-3988
Old 07-12-2011, 02:41 PM   #6
HS13KLS
HS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant future
is for S14 or 5 lug
wait.. so its not for a s13?
And since god speed makes angle kits now too..? interesting.. lol
HS13KLS is offline   Reply With Quote
Old 07-12-2011, 02:46 PM   #7
Sarom_ps13
Sarom_ps13's Avatar
Sarom_ps13 is an unknown quantity at this point
Interested, and since its godspeed i would like to know the $$ also. and reviews would be nice.
Sarom_ps13 is offline   Reply With Quote
Old 07-12-2011, 03:07 PM   #8
da_crew10
da_crew10's Avatar
So these will not work
With ichiba conversion hubs ?
Old 07-12-2011, 03:07 PM   #9
Fatboy Garage
It fits S13 or S14 as long as you have 5LUG.
Godspeed Project
El Monte CA 91733
P: 626-442-3988
Old 07-12-2011, 03:14 PM   #10
slider2828
slider2828's Avatar
Are there plans to make it compatible with 4Lugs? And do you know what is the reason why 4lugs are not compatible?
Turn and Burn!
Old 07-12-2011, 03:36 PM   #11
essforteen
essforteen's Avatar
Trader Rating: (50)
essforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant future
Feedback Score: 50 reviews
When they say it doesnt work for 4 lug im assuming thats because its built from the s14 knuckles and if you wish to stay 4 lug get some s14 4 lug hubs!
S14 and s13 have different spindle sizes there fore you must use s14 hubs to make these work! 4 or 5 lug!
Correct me if im wrong!
essforteen is online now   Reply With Quote
Old 07-12-2011, 03:38 PM   #12
soreballz
soreballz's Avatar
So, what you're trying to say is that it's a modified S14 knuckle, so to use it on an s13, you need 5lug S14 hubs (not Peak, Ichiba, eBay, modded J30s, etc) and s14 front ball joints or LCAs, yes?
EDIT: Yeah, what the guy above said. lol
So yeah, these SHOULD work on an S13 or S14, 4 lug or 5 lug, when using S14 hubs and LCAs (or just the ball joints).
AMIRITE?
-Kyle
Last edited by soreballz; 07-12-2011 at 03:43 PM.. Reason: Poster above beat me to it.
Old 07-12-2011, 03:42 PM   #13
!Zar!
!Zar!'s Avatar
s13 uses 30mm wheel bearing, s14 uses 32mm wheel bearings iirc.
Old 07-12-2011, 04:04 PM   #14
PoorMans180SX
PoorMans180SX's Avatar
EDIT: first pic didn't load.
Old 07-12-2011, 04:36 PM   #15
RurouniMidnight
RurouniMidnight's Avatar
Omggggeeee
Old 07-12-2011, 05:09 PM   #16
shalezzz
shalezzz's Avatar
shalezzz is an unknown quantity at this point
Hey guys, you're not very smart.
These go on the TIE RODS where they connect to the steering rack.
So what the freak does having 5-lug have to do with anything?
Also, 2 of each spacer is way overkill. Your rack can't even move that far.
Boy, does Godspeed sure know what they're doing...
I think it has to do with spindle sizes, your replacing the whole knuckle therefore and s13 4 lug wheel bearing will not fit on this knuckle, and to what you said about the tie rod piece those spacers are typically just an o and move into the rack, ive never tried a god speed product but Id be interested to see a reasonably priced aftermarket knuckle wig good quality, and will this correct suspension geometry on lowered vehicles? Or just allow more angle?
shalezzz is offline   Reply With Quote
Old 07-12-2011, 05:27 PM   #17
Fatboy Garage
Yes this is actually a modified S14 knuckle.
To fit to S13 you will need to either use a S14 LCA or the ball joints as soreballz said or you can bore it out to 16mm id since ours is 14mm id.
Also as for the shaft of the spindle, ours is 32mm so you have to use a S14 HUB either it being 4 or 5 lug just as long as its 32mm id.
As for it fitting on a S14 it should fit directly.
As for the spacer they are optional to put on, you don't HAVE to use them, we are just providing extra if necessary.
Godspeed Project
El Monte CA 91733
P: 626-442-3988
Old 07-12-2011, 06:43 PM   #18
s13coupedrfter
s13coupedrfter's Avatar
s13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond repute
So the big question is whats the price?
s13coupedrfter is offline   Reply With Quote
Old 07-12-2011, 07:39 PM   #19
turtle m3th
turtle m3th's Avatar
Trader Rating: (41)
turtle m3th has a reputation beyond reputeturtle m3th has a reputation beyond reputeturtle m3th has a reputation beyond reputeturtle m3th has a reputation beyond reputeturtle m3th has a reputation beyond reputeturtle m3th has a reputation beyond reputeturtle m3th has a reputation beyond reputeturtle m3th has a reputation beyond reputeturtle m3th has a reputation beyond reputeturtle m3th has a reputation beyond reputeturtle m3th has a reputation beyond repute
Feedback Score: 41 reviews
Why are you guys utilizing spacers on top of spacers?
"cigarettes killed my father, and raped my mother!"
turtle m3th is offline   Reply With Quote
Old 07-12-2011, 07:42 PM   #20
DC Dan MAX USA
DC Dan MAX USA's Avatar
Trader Rating: (79)
DC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond repute
Feedback Score: 79 reviews
i just threw up a little in my mouth
How To order: You can order directly from our zilvia advertiser threads. When you add to cart, you get an instant shipping estimate, & the cart will remember all of your items as you move between forum threads and our website www.poweredbymax.net until you remove them or check out. I can also calculate estimates manually for you but the cart's estimates are way faster and more accurate.
Order Inquiry: IM me your real name and paypal address.
Thanks for your business!
DC Dan MAX USA is offline   Reply With Quote
Old 07-12-2011, 08:09 PM   #21
soreballz
soreballz's Avatar
-Kyle
Old 07-12-2011, 08:56 PM   #22
thefro526
thefro526's Avatar
Not trying to hate or anything but:
I'm fairly certain that the whole double spacer thing is a horrible idea. Most people who run spacers greater than 1/4" or so (~7mm) and knuckles end up moving their rack forward or running offset spacers (essentially does the same thing - kind of) so that they don't over center to all hell and back.
The fact that you seem uncertain as to whether or not this will fit an S13 concerns me as well...
thefro526 is offline   Reply With Quote
Old 07-12-2011, 09:10 PM   #23
1on1
1on1's Avatar
interesting.
instagram
Old 07-12-2011, 09:44 PM   #24
azndoc
azndoc's Avatar
Trader Rating: (47)
Feedback Score: 47 reviews
Not trying to be a dick, but have you guy done any tests or just made it now and starting to test it out?
How much more degrees than stock? Did you guys just copy off some other company and if so who?
Thanks
azndoc is offline   Reply With Quote
Old 07-12-2011, 10:23 PM   #25
DC Dan MAX USA
Trader Rating: (79)
Hey guys can you at least pick another color besides this one? I got it covered already, thanks.
Old 07-12-2011, 10:52 PM   #26
blktopsr20
blktopsr20's Avatar
Trader Rating: (83)
blktopsr20 is an unknown quantity at this point
Feedback Score: 83 reviews
haha epic. are those nose rings or some donkey D intimate accessories.
blktopsr20 is offline   Reply With Quote
Old 07-12-2011, 10:52 PM   #27
stricnynel0s
stricnynel0s is an unknown quantity at this point
this is a shitty situation; innovation, invention and competition are healthy for our industry but plagarism and copying sucks. I am not going to act high and mighty ( i am running godspeed sway bars) but this looks identical to the PBM angle kit. How does the PBM kit compare to the stance kit out of curosity or how does pbm kit compare to the gspeed one ? obiously fatboy is not making these kits just selling them so its kinda like killing the messenger, but maybe with more information on setup we can get an idea of it and functionality.
stricnynel0s is offline   Reply With Quote
Old 07-12-2011, 11:13 PM   #28
NismoTuner21
NismoTuner21's Avatar
NismoTuner21 will become famous soon enoughNismoTuner21 will become famous soon enoughNismoTuner21 will become famous soon enough
Hahahaha @ Dan!!!
Sup with the Ackerman bruh, you guys fix that too?
NismoTuner21 is offline   Reply With Quote
Old 07-12-2011, 11:15 PM   #29
JDM_Tuner
JDM_Tuner's Avatar
Trader Rating: (35)
JDM_Tuner is an unknown quantity at this point
Feedback Score: 35 reviews
Man does godspeed just copy everyone, from the looks of it...
the ring spacers are copies of PBM,
the bigger spacers are copies of Driftspeed spacers
and the knuckles look like MA-Motorsports knuckles.
JDM_Tuner is offline   Reply With Quote
Old 07-12-2011, 11:56 PM   #30
wangan_cruiser
kouki man
wangan_cruiser's Avatar
Trader Rating: (36)
wangan_cruiser is close to perfectionwangan_cruiser is close to perfectionwangan_cruiser is close to perfectionwangan_cruiser is close to perfectionwangan_cruiser is close to perfectionwangan_cruiser is close to perfectionwangan_cruiser is close to perfectionwangan_cruiser is close to perfectionwangan_cruiser is close to perfectionwangan_cruiser is close to perfectionwangan_cruiser is close to perfection
Feedback Score: 36 reviews
Send a message via AIM to wangan_cruiser
lol. godspeed let the big boys do the development, design then copy
how much?
wangan_cruiser is offline   Reply With Quote
