![]() Join Date: Apr 2013
MAF question!
Quick question guys, I have a s15 sr20det and need some information. I have a maf for a zenki 14 sr20det which has the square plug. I know the plugs are different between the zenki maf and kouki maf(which will work the s15 because the same oval plug) but is there any other difference there. I'm gong to wire it up for start up and break in if it will work, I have a z32 maf but I'm waiting until I get it running properly before I take it to the tuner. Thanks in advance!
#3 | |
So I can't splice in the s14 zenki pig tail (square) onto the harness and use the zenki maf? Or are you just saying the plugs are different shaped. Sent from my iPhone using Tapatalk |
![]() Join Date: Jun 2005
My understanding is that wont matter. Zenki maf is not combatable as in the ECU will not recognize it.
| 92 S13 Hatch | 92 S13 Coupe | 95 S14.5 | |
Then get the ECU tuned & install the Z32 Maf or wire in an SAFC... Why waste time with a stock maf if you are just replacing it?
