89-94 rear hatchback bumper support $30
89-94 coupe rear bumper $80 with bumper support Doors (motor, window, switches) 89-94 complete doors shell - $100 complete 8-9 out of 10 89-94 manual windows Complete DOOR SET- $160 a set complete door 8.5 out of 10 89-98 driver/passenger side mirror - $40 each power or manual LE power door panels clean $150 9.5 out of 10. Interior (*Seats, interior panels, arm rest, center piece, dashboard, etc**) dohc cluster $100 95-96 white face cluster SE $100 ~2xx,xxx ULTRA RARE 89-94 NISMO 140MPH CLUSTER $350 ~165k 89-98 Clean black or blue cluster trim $40 1989-1994 or 1995-1998 complete center console with arm rest $80 Working A/C CLIMATE CONTROL - 1989-1998 $40 89-94 OEM coupe quarter window glass - $60 each obo 89-98 Glove box $40 stock s13 seat with rail cloth or brown leather $30 passengerside only. Nissan 240sx 1995 - 1998 Zenki, Kouki S14a clean flawless condition steering wheel $70 no air bag Airbag passengerside - $40 no cracks 1/4 quarter panel glass- $80 Tail Lights JDM kouki tail lights $350 95-98 89-94 3 piece hatch tail light or coupe $60 95-98 3 piece smoked zenki tail lights $60 89-94 d-max LED smoked red with oem 180sx center garish - $550 Plug and play. Cooling stock s14 fan shroud $60 Brake System - 300zx to 350z brake caliper bracket $120 NEW - BMC 1 1/16 brake master cylinder for s13 s14 s15 z32 $120 NEW - 89-98 S13 s14 Stock Front brake caliper with brake bracket $60 a pair -300zx big brake upgrade bbk $350 obo with rotors Exhaust System 1995-1998 CAT Converter aka Down pipe $100 95-98 Catback exhaust system $100 with aftermarket muffer Serbling 89-94 Rs-R GT-2 Full catback $350 Megan Type II exhaust s14 $320 perfect for n/a or turbo low key exhaust Megan collars $60 obo ** NEW* New derlin Motor Mounts KA/SR Direct bolt on - $80 89-90; 91-94 exhaust manifold - $60 89-98 starter / alternater $60 89-90 or 91-94 S13 down pipe- $50 MAF (mass air flow sensor) SOHC 89-90 $60 or SR, - Suspension -oem stock s13 or s14 suspension set. $120 - new Megan tension rod $80 s14 - Drivetrain S14 Front subrame $120 Straight NO BENTS OR DAMAGED. 95-98 S13 REAR subframe clean $80 BARE or $250 complete with diff; S14 $350 Complete ; Subframe Z32 $80 95-98 $120 open diff aka 3rd member, pumkin 89-98 s13, s14 6 bolt axle $50 each or $80 a set. 89-94 s13 rear control arm $50 each s14 $80 Each s13 or s14 traction arm, toe arm, camber arms - $20 each or $30 a pair. s13 rear 4 lug hub $40 or $60 for both. GOOD BEARING S14 front control arms $220 or $120 each OEM Full front end conversion for s15 $2200 Vis carbon fiber hood -450 oem spec r bumper -550 oem spec black housing headlights -650 brackets hood hinges conversion fenders -350 Semi Complete kouki conversion $1200 for the whole set or part out Seibon carbon fiber vented hood with flush mount hood pin lock (key included) $450 JDM bumper support $150 oem bumper retainer $100 Kouki fenders white $500 kouki headlights $500 x2 passenger x1 driverside kouki corners $120 Jdm kouki grill $150
PARTING OUT S13/S14 NEED PARTS PM ME! Last edited by iLagX; 04-19-2014 at 04:20 PM.. |
