buying 240 advice
so i went and looked at a s14 today, it ran pretty well but the guy said it had a cel for a knock sensor and the powersteering fluid was bubbling.Is that normal? Is a knock sensor an easy fix?
http://dallas.craigslist.org/mdf/cto/2650428816.html |
![]() Join Date: May 2011
PS isnt bled properly or he may have been one of the idiots who put PS fluid in instead of ATF.
You should look around I picked up a 92 Hatch with 120K on it for 600 bucks. Just keep looking. Buying advice, look for frame damage, rust, abuse ( every 17yr old thinks there a drifter so look at the tire tread subframe, bushings ) just look for the common things you would on any used car. TRY to find a unmolested stock car buying someone elses project will just end up as a money pit.
![]() Join Date: Jun 2006
Also if your gut doesn't feel right about a deal.. trust your gut... don't just buy a 240 just cause you have to have one or want one sooooo bad.. the right deal will come and when it does you will feel relieved you waited.
Driftphreak87 |
