| Media Forum / Pictures / Videos Forum dedicated to media, such as pictures and videos. |
![]() Join Date: Sep 2011
just thought i would post up some pics of what i have going on. i hope to have her done by spring and rolling all next year.
here's the goods list
not too much needed still to be running basically doing a hour here and a few hours there when i have time. ill post updates soon ![]() ![]() ![]() ![]() ![]() Last edited by 300zjab; 09-14-2011 at 07:56 AM.. |
![]() Join Date: Jul 2005
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 2 reviews
what type of oil pump are you using? have you modified the oil system?
On my 05U build im running a nitto pump, a 1.2mm restrictor (rear blocked off completely) and a rear head drain to oil pan.
it used to be until i decided i wanted it to get done before 2012.. lol they did good work they did all the motor work and subframe work just have a lot on their plate..
Good decision to pull it out, the world would end before they'd get it done. Good luck, I expect to see it around. How soon do you think it'll take you?
'79 280ZX: Heartless garage troll. VK56? '06 STi-Daily. |
ill; have it on the road in spring. no sense in rushing things now for winter. plus working 55+ hours a week doesnt leave much wrench time. she will be on the road in spring
Nope they did the engine work and subframe work. I Picked the car up a month ago because I thought a year and a half was enough time and I might as well finish it myself.
#24 |
![]() Join Date: Dec 2003
mmmm money.... keep going.
#29 |
i plan on having my fuel lines assembled and run by the end of the week and hope to get my gauges mounted and wires run, as well as get my harness run and everything plugged up =)
getting closer.. |
#30 |
current status:
![]() ![]() ![]() ![]() got the pumps in and all wiring run to the relays and my kill switch. also finishing up my gauges and that wiring in the next few days as well as fuel lines. ill have a update this weekend below is basically what i used for my pump setup and it should work out nicely ![]() |
| 300zx, rb26, z32 |
