DOC RACE TURBO MANIFOLDS Blowout Holiday Sale & FREE Shipping!!!
WE HAVE DEFINATELY BEGAN DRINKING EARLY WITH TOO MUCH EGG NOGG AND BUBBLY AS OUR HOLIDAY SALE WITH FREE SHIPPING IS LEAVING US WITH NO PROFITS ON THESE QUALITY GOOD 'OL USA MADE DOC RACE TURBO MANIFOLDS AND INTERCOOLERS!!! CONSIDER IT A PRESENT TO ALL OUR FELLOW ZILVIA NISSAN FANS FROM THE BESTEST DOC RACE AUTHORIZED DEALER - PERFORMANCE AUTOWORKS!!! POST YOUR INQUIRIES HERE, PM, OR EMAIL US FOR OUR BLOWOUT HOLIDAY PRICES. MAKE IT A VERY MERRY CHRISTMAS, HAPPY HANUKKAH, KWANZAA, AND/OR FESTIVUS FOR THE REST OF US BY PURCHASING ONE OF THESE BAD BOYS FOR A LOVED ONE OR IF YOU LOVE YOURSELF!!! HERE ARE THE DETAILS AND PICS OF EACH MANIFOLD. WE ALSO HAVE MANIFOLDS FOR 350Z TURBO, Toyota 2JZ, 1JZ, Mazda 93+ RX7, Mazda Miata, Honda and more! We carry every item DOC Race manufactures. See their website for further details... DOC Race Store, Turbocharging Components For SR20DET... Nissan SR20DET T3 Top Mount Manifold Application notes: -T3 flange -Option for 2-bolt 38mm, Tial MVS or MVR/44mm wastegate flange -Retains AC Stainless downpipes are also available upon request for $350 in 3" Stainless with 4-bolt, 5-bolt or V-band flange. The DOC Race Topmount Turbo manifold is for the more extreme setup looking for the potential limit of the vehicles engine. The DOC Topmount manifold can still be used for “streetable” vehicles, but is solely designed to make maximum horsepower and allow you to fit much larger frame turbo’s then our traditional ramhorn. D.O.C. still applies our elaborate porting process to complement maximum flow within ALL of our manifolds. ************************************************** ******* Nissan SR20DET T25 Bottom Mount The DOC Race SR20DET T25 Bottom mount turbo manifold places your t25/28 framed turbocharger in the factory location. Made from sch 40 stainless steel and a true merge collector this manifold will maximize the output of any turbo that will fit on it. ************************************************** ******* Nissan SR20DET T4 Front Facing Manifold Application notes: -Open T4 flange (T3 option available below) -Single Tial MVR or Dual MVS gate option -Retains Powersteering and Air Conditioning on S Chassis The DOC Race T4 Topmount Turbo manifold is for the more extreme setup looking for the potential limit of the vehicles engine. This manifold is capable of well over 1000hp in our Twinscroll version and is designed for peak-power situations. The DOC Topmount manifold can still be used for “streetable” vehicles, but is solely designed to make maximum horsepower and allow you to fit much larger frame turbo’s then our traditional T3 Center set manifold. D.O.C. still applies our elaborate porting process to complement maximum flow within ALL of our manifolds. ************************************************** ******* Nissan SR20DET V-Band Top Mount Manifold Application notes: Tial V-band Inlet flange Option for MVS or MVR V-band wastegate flange Retains AC Stainless downpipes are also available upon request for $350 in 3" Stainless with 4-bolt, 5-bolt or V-band flange. The DOC Race Topmount Turbo manifold is for the more extreme setup looking for the potential limit of the vehicles engine. The DOC Topmount manifold can still be used for “streetable” vehicles, but is solely designed to make maximum horsepower and allow you to fit much larger frame turbo’s then our traditional T25 Bottom-mount. D.O.C. still applies our elaborate porting process to complement maximum flow within ALL of our manifolds. ************************************************** ******* SR20DET High Port Billet Intake Manifold DOC Race Billet SR20DET Intake Manifold. Works with most throttle bodies including the Ross Machine 90mm. DOC Race Intake Manifolds are designed for extreme boost applications with increased plenum size and calculated runner length for optimum power delivery. These intake manifolds have CNC intake ports for proper airflow through the plenum. Intake manifolds are standard with a billet flange and an array of throttle body possibilities such as the sought after 90mm in the Mustang bolt pattern. DOC still applies our elaborate porting process to complement maximum flow within ALL of our manifolds. This Intake Manifold is designed for maximum output of your SR20DET engine. ECU tuning will be necessary to gain all the possible torque that comes with this High Volume Intake Manifold. -Will also work with factory-medium sized cams and smaller frame turbo's for mid-range gains. ************************************************** ******* For KA24DE Turbo... KA24DE T3 Topmount Manifold DOC Race Nissan KA24DE Topmount Manifold -Fits ALL Twincam KA24DE Engines, 91-98 240SX -Powersteering pump bracket modifications necessary Available with a MVS or MVR wastegate flange, this T3 turbo manifold is for the more extreme setup looking for the potential limit of the vehicles engine. The DOC KA Topmount turbo manifold can still be used for “streetable” vehicles, but is solely designed to make maximum horsepower and allow you to fit much larger frame turbo’s then our traditional bottom-mount T25 manifold. D.O.C. still applies our elaborate porting process to complement maximum flow within ALL of our manifolds. ************************************************** ******* KA24DE T25 Bottom-Mount The DOC Race Nissan KA24DE T25 Bottom-mount Turbo Manifold was designed to be a bolt-on manifold that will support most Internally Gated T2 frame turbo's. This manifold is able to use the SR20DET T25 Turbo outlet and retains A/C and Powersteering. Made with 304 sch 40 Stainless steel and a true merge collector, this hand-built piece will take your T28 frame to the maximum! ************************************************** ******* For RB20/25/26... RB20/25/26 Openscroll Topmount DOC Race Open T4 Topmount available for RB20/25/26 -T4 Open Inlet Flange -Single MVR Wastegate flange standard The DOC Race RB Topmount Turbo manifold is for the more extreme setup looking for the potential limit of the vehicles engine. The DOC Topmount manifold can still be used for “streetable” vehicles, but is solely designed to make maximum horsepower and allow you to fit Larger Frame Turbo's. D.O.C. still applies our elaborate porting process to complement maximum flow within ALL of our manifolds. ************************************************** ******* RB20/25/26 Twinscroll Topmount Application Notes: -Standard with Dual Tial MVS V-band wastegate outlets -Up to 4" downpipe Tubing specs: 1.660" OD, 1.380" ID, 0.140" wall rated for 1300hp The DOC Race Twinscroll Turbo manifold is similar to our Topmount manifold application. Our Twinscroll manifold is for maximum flow of your engine and turbo including the best possible spool and no limitations of the maximum output of your combination. DOC Race Twinscroll manifolds have had years of development in order to utilize the proper exhaust pulses to eliminate unwanted exhaust backpressure and vale overlap, in-turn giving you maximum airflow. This manifold is simply the most efficient available on the market! D.O.C. still applies our elaborate porting process to complement maximum flow within ALL of our manifolds. POST YOUR INQUIRIES HERE, PM, OR EMAIL US FOR OUR BLOWOUT HOLIDAY PRICES. Again Happy Holidays and HAPPY NEW YEAR to all fellow Zilvia members and their families from Performance Autoworks!!! ![]() |
![]() Join Date: Sep 2005
![]() ![]() ![]() ![]() Feedback Score: 20 reviews
SR T25 bottom mount price, please.
BRICKHOUSE PRODUCTS
IG @brickhouse_products |
![]() Join Date: Feb 2012
3" sr20det downpipe..
Is it just one piece or the two piece like Mazworx that replaces the bottom downpipe before the cat? Noone selling these has been able to give me any info on the downpipe. Paypal ready I need one TODAY. Thanks! |
#17 |
Except mine...
Same exact thing I went through with a previous dealer. Ignored and eventually told "oh, doc didn't give any info on the downpipe.." Thanks anyway.. |
#18 | |
Dude, I am waiting for the exact answer to come in from my buddies at DOC RACE. I just emailed them early this morning. It's only been a day since you asked us the question. Patience is a virtue. LMK if you still need an answer. Regards, Will |
#21 |
#24 |
Merry Christmas fellow Zilvia members!
Some of you must be very happy children when Santa delivered your shiny Doc Race manifolds! Not to worry for those that missed out - the UPS man can deliver the same shiny manifold to your door now if you PM or post on thread for our super low beat all blow out price! |
