#61 | |
#63 |
![]() Join Date: May 2007
Hey brother what did you end up having to do for the transmission mount? Is it bolted up with just a single bolt?
What did you do for powersteering?
#64 | |
![]() Join Date: Apr 2010
1st option- Use LS400 Power Steering pump which has reservoir mounted on it and get your KA high pressure hose extended to reach over to the pump. 2nd option- Still need to get your High Pressure Hose extended BUT you use a SC400 Power Steering Pump which doesn't have the reservoir mounted on it. This allows you to keep your stock S-Chassis reservoir and just run your lines to it. Big fat one will connect to the Pump and the other back to your Rack. |
#65 |
thank you so much to referring me to the correct build thread of yours! I just went to a local car rebuild yard that has a 1uz in their storage BUT no wiring harness :/. they said they could get another car with everything in it and I could come pull everything I needed for the same price($350). I know that's a higher price than what most of you guys have paid but its the closest I have available to me. and since I live a mile down the road they will bring it over after I pull it for free. so yay for no shipping fees. but onto the questions.
1. what all should I pull from the car if I decide to do it myself? 2. what king of mpg are you getting from daily driving? bc this will be my daily as well. 3. what all did you replace when you rebuilt the motor? 4. if you do not mind (please do not mind lol), how much did this swap cost you? under $3k? thank you ahead of time for the feedback! your car is immaculate brother :thumbsup: |
#67 | |
#68 |
So my question is simple. How happy are you with the power of the 1uz in your s14? If I did not miss anything you are running an early model 1uz with 261 hp and 268 lf ft torque. This is the swap that I want but before I dive in I want to get some driving impression comments from people that have completed this swap. I also have an s14 and I have gone the route of the ka-t and I blew the motor. Now I would like to go back to na power but the lsx is just to costly. Thanks!
#69 | |
Spins 255 g-force tires. |
#72 | |
I'm very happy about the power actually. The torque is so freaking badass! In my opinion I think it's a good build for the buck. Only issue you will run into is the modification of the Driver side Exhaust Manifold. Other than everything should be pretty much bolt on. Like you saw I purchased the full kit from Brett at swap1uz.com excluding the Driveshaft. The Driveshaft I got custom made as a one piece at local shop. This car is my Daily Driver and have no complaints whatsoever.
#74 | |
#75 | |
#76 |
Deffinitly one of the tightest swaps I've seen in a while. It's nice not only seeing the pics and reading all the good info, but watching videos on your progress. Being able to hear it and see it go is f'n dope. Keep up the good work bro
#78 |
Thank you all for the love! I'm glad i've put a positive impact in you guys to do the swap as well. The KA Transmission feels like it needs an extra gear but then again I did change my rear to a z32 so that may have something to do with it as well. The car is my daily driver and I really don't have anything to complain about it. It's definitely a neck breaker though lol. Later on i'll be upgrading to a 350z transmission.
#79 | |
Going to drop my car off Aug 3, 2013: 10 days and counting. |
#80 | |
#81 |
Small shop here in Atlanta previously Lethal Injection. I very excited because I have not been able to drive my 240 in over a year and a half. Rrrr! I really miss it and most people look at me funny when I say that because I have an 08 WRX. Its not the same. The WRX does everything well but I also don't want to brake it, my wife would have a fit. The 240 always feels right when I'm driving it, its special.
#83 |
Did you ever get around to the pictures for the wiring? if not, can you link me to what you used to go by? thanks.
#85 |
![]() Join Date: Apr 2006
I dont know if I missed it, but are u planning to dyno it?
How much do you think you have into the swap? Just a ballpark Nice work by the way!
Project cars: "Fail to plan, plan to fail"
#86 |
zenkiset- PM me for wiring.
[email protected]- Yes I got it for $260.00 Slippin'eight-nine- I haven't dyno'd it yet but I'd say with the elimination of Fan clutch and AC Compressor I'm doing like 270HP and 270TQ. That's just my estimate it could be more or it could be less. |
#87 |
![]() Join Date: Mar 2005
Trader Rating: (41)
What's up with a real in car cluster video Serg? I've only seen this thing putt down the street, hahaha!
"cigarettes killed my father, and raped my mother!" |
#88 | |
