![]() Join Date: Feb 2011
lower trans harness
hey guys i have a question about the transmission harness:
from my understanding looking at the harness there are 3 sensors and the speedo sensor is seperate, but the one connector that confuses me is a two wire connector in the same group as the three sensors. the wire colors are yellow with a blue stripe and black and from the looks of it it wasnt connected and all grimey. does any body know which/ where it goes.? |
![]() Join Date: Mar 2011
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 21 reviews
Could have used the Small Questions thread. . .
Info is in the FSM Those are for the vehicle speed sensor http://www.nicoclub.com/FSM/240sx/91-94/Foldout.pdf - Page 6
DLG - DIRTYLOVE |
you know i would be able to do that if the wires on my harness werent all fried up and melted together, but i just went with i dont need any of those sensors on the trans except speedo so off the harness they go, dont really need reverse lights since the car only sees the road once in awhile
5spd lower harness contains:
Speed sensor <-2 wire Neutral sensor Reverse sensor 5th gear sensor Starter power Starter signal Alternator power Alternator ground Alternator S/L plug <-2 wire Oil pressure switch
