#121 |
Thank you! But what about the actual plastic gear that sits on the shaft inside the tail housing? Am I doomed to track down a blown 5 speed and modify it to work? Or is there a direct replacement for the s15 gearbox?
#122 | |
![]() Join Date: Dec 2006
Trader Rating: (28)
![]() ![]() ![]() Feedback Score: 28 reviews
They did not mention that gear part number. You need to modified other gears for test fit. And for the extension housing you already have it. |
#123 | |
![]() Time to go 350z trans, finally. There's a video on my IG of how noisy it is. The last trans did the same thing until it just didn't want to go into gear at all and I'd get stuck in neutral while driving.
@ddaapphh | @spectuned |
#124 |
![]() Join Date: Jul 2005
If you drive it nice, it can last a long time at 400bhp. No hard launches, no slicks, no drifting, no terrible clutch kicks.
The only reason I am not using a six speed right now is because of their cir-clip issue. |
#126 | |
Did you figure this out? I used the USDM "speedo drive gear" to suit my chassis, ie: speed sensor (5MT - KA - 95) and had it enlarged to fit (I.D.) 28mm. This part is inside the transmission on the output Shaft, so get the parts guy that has experience with the exploded diagrams, and not the 18yr old. |
#127 | |
Anyone got the 6mt bell housing bolt sizes or a set I can buy? Bought a 5mt set but half the bolts are way too short - go figure |
#128 |
#130 |
If anyone is planning to ditch the dual mass flywheel, keep in mind that you will most likely need standard s13/s14 flywheel bolts. The s15 bolts are way too long. ARP seemed to be the cheapest. That's what I used with a Nismo/Autech flywheel.
#131 |
Is there anyone out there with confirmed drive shaft fitment info? my car is s14/abs car. I purchased what i was told is a 6-speed s15 drive shaft. Fits into output of transmission just fine but is too long. The rear section from diff to carrier is off by 1/2" approx. The front section is entirely too long by probably 2-3". Anyone else compile any data? I figure i can locate a stock rear section and have the front section shortened, but was hoping for a bolt in solution.
#132 |
I have an Autech S15/6 speed that I'm swapping in a Datsun roadster. It has 60K miles on it. I'm thinking that I should at least replace the clutch disc before I install in the car. thoughts? What clutch disc should I get to replace the one I have?
#136 | |
3.916 was only on A/T cars, 3.692 was M/T, and 4.08 was NA and all USDM models. |
#137 |
Quick question if somebody dosent mind answering....
Bought a S15 6MT to put on my SR20DE drift car It came with the shifter, but no knob so I bought an eBay special, I've tested all the gears and its fine... But how do I engage reverse?! I've tried pushing down and pulling up but no luck? Do I need a special gearknob to pull up? Bit confused haha Sorry if this sounds stupid! Also sorry again for bumping an old thread Sent from my E5823 using Tapatalk |
#138 |
ITS LISA'S FAULT!!!
![]() Join Date: Jun 2003
Trader Rating: (41)
its a 90s 6 speed... so probably just push all the way to left and up, or all the way to the right and up or down. no need to push down or pull up on the gear shift.
#143 | |
I know how reverse works Sent from my E5823 using Tapatalk |
#144 | |
Trader Rating: (28)
This is correct no downs or ups. If you still cant put it in reverse. Try the Japanese trick I posted. |
#145 |
#148 | |
Because I didn't know that?
No need for the attitude. Quote:
#150 | |
Trader Rating: (28)
No sweat mate! Hey wonder if you can help me out to find me a s15 evaporator box and s14a front bumper side cover/caps? (pictured) ![]() |
