Banned from the Marketplace
![]() Join Date: Oct 2008
Trader Rating: (32)
![]() Feedback Score: 32 reviews
***Complete part out of Nissan 240sx S13 and s14 s15 Silvia front ends***
Exterior: (**Front ends, Bumper, Fenders, Hood, Doors, Rear quarter panel, Rear bumpers**) s13-s14-s15 - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - Headlights 95-96 S14 Zenki Headlights$100 Corner $60. SOLD 89-02 S15 Silvia Headlights HID READY $600 No broken tabs - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - Fenders (fender linner, metal fender, fiberglass, bracket, screws,) 89-94 Metal fenders $70 each. Driverside Clean 89-94 fender $20 for ok condition ones passengerside only SOLD S13 GOOD CLEAN fender linner - $30 each Exterior - Rear quarter panel 89-94 rear hatchback $80 pick up only Rear quarter panel WIDE BODY B-Magic Aero 30mm 95-98 FRP FENDER $250 CLEAN OEM 95-98 KOUKI SIDE SKIRTS $250 2 piece. SOLD - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - Hoods (Fiberglass, oem metal, carbon fiber) 89-94 s13 pop up headlight hood 240sx $50 Siebon Carbon fiber S15 hood $350 obo - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - Rear trunk (glass, hatchback, Trunk lid) Se s13 sunroof cover $40 come with oem brown bag sunroof glass no RUST OEM NISSAN 95-98 $150 95-98 Sunroof Unit COMPLETE $250 SOLD 89-94 Rear hatch s13 with glass $20.. SOLD 89-94 clean wingless coupe trunk $80 95-98 wingless trunk s14 $80 95-98 trunk with oem spoiler $100 SE SOLD - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - Bumpers (bumper cover, metal bumper support reinforcement, foam) 89-94 240sx Pop up headlight, Chuki Front bumper with SE LIP $150 obo Rear Coupe bumper Clean $70 89-94 front $30 or rear bumper support $20 each S13 240sx bumper support foam $20 Zenki 95-96 S14 Jdm black zenki bumper $200 Driver And Passenger Signal Light $60 a pair Amber JDM ZENKI BUMPER/HEADLIGHT RETAINER CLEAN $75 Tail Lights 89-94 tail light $100 a set! OEM obo 95-98 S14a Kouki Complete TAIL-LIGHT $350 obo - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - Doors (motor, window, switches) 89-94 passenger door with manual windows - $40 has few dings 89-94 Power windows Doors Complete - $160 a set complete door and harness, motor/ regulater/glass included 95-98 driver/passenger side mirror - $40 each Interior (*Seats, interior panels, arm rest, center piece, dashboard, etc**) Nissan 240sx 1989 - 1994 Hatchback, Convertible, Coupe a/c CLIMATE CONTROL - $30 89-94 OEM coupe quarter window glass - $80 each obo hatchback rear black quarter panels - $30 each or $50 for both 89-98 Glove box $20 Nissan 240sx 1995 - 1998 Zenki, Kouki S14a Door Panels -$50 a set rear black quarter panel - $40 for both Airbag Driverside and passenger r - $200 or 150 each passenger side no cracks 1/4 quarter panel glass- $30 automatic gear shifter - $20 Internals: ( **Engine, Transmission, Brakes, Suspension, Control arms, Axle**) s13 abs brake module/system $40 no problem whatsoever.. Brake System - - - 89-98 S13 Stock Front brake caliper with brake pad $25 each or $40 for both - - - 89-94 Rear caliper $40 each. GOOD SEAL NO LEAKS!l - - - Front 180sx big piston caliper $100 pair WITH 4 lug ROTOR - Engine and Transmission NEW Delrin Stiff Motor Mounts KA/SR Direct bolt on - $100 A SET - - s13 fan shroud upper and lower included, DOHC $50 5 piece 91-98 KA24DE Oem clean Flywheel $40 ( need resurface) 89-94 single cam 240sx stock header - $30 , 89-98 starter $50 ( working condition can go with you to autozone to test it out.) 91-98 twin cam header shield - $20 off a s14 1995 91-94 S13 dohc clean down pipe - $80 91-94 EGR piping $30 MAF (mass air flow sensor) SOHC 89-90 $40 , DOHC 91-94 $80 S14 97-98 $160 95-98 AEM INTAKE WITH DRY FLOW FILTER $120. All hardwares all included. SOLD -Front + Rear Suspension 95-98,89 -94 open diff aka 3rd member, pumkin COMPLETE $80 each 89-98 s13, s14 6 bolt axle $30 each s13 or s14 Stock shocks and spring $150 obo Complete front and rear. 89-94 s13 rear control arm $50 each s14 $100 Each s13 or s14 traction arm, toe arm, camber arms - $20 each. s13 hub+spindle - $40 each side.or $150 for complete s13 front lower control arm -$40 each S14 front lower control arm $100 each s13 front/rear sway bar - $20 each Exhaust System 89-94 Coupe, fastback, hatchback, convertible Rs-R GT-2 Full catback $350. DIRECT BOLT ON OEM SETTING Donuts/ Spare tires $20 each. Stock steelies - $20 Last edited by mazersx; 03-29-2010 at 04:17 PM.. |
![]() Join Date: Apr 2008
5 lug hubs?
where are you located?
https://www.linkedin.com/in/hassanbakar |
#17 | |
Trader Rating: (32)
$100 no rust.
what headlight are you talking about?? s13 pop up yes it does. Quote:
5 lug conversion complete $500. PICKED UP. |
