Has a faulty master or slave cylinder ever caused clutch pedal 2 be difficult 2 press
I usually don't use a "2" for the word to but it wouldn't all fit in the title.
Anyways I have a 13 with an SR, I just bought. It is super hard to press the clutch pedal. It always come back but its just very hard to press. Also, it just barely disengages the clutch. I know I can adjust the rod coming out of the master but that isn't the cause of the problem. I took a short video of the motion of the master was. It seems like the travel is not enough. I figure when a master or slave brake if anything you get less resistance in the clutch pedal. Any insightful information is appreciated. VIDEO0112.mp4 video by o_alcha3 - Photobucket |
![]() Join Date: Apr 2008
Unless it's a custom one like the one I had once, it was a custom triple strapped pressure plate pucked disc, broke my pedal multiple times, then I ended up switching to a OS GIKEN twin disc, which btw felt awesome
#7 | ||
the pedal was welded back together so i swapped it out with the another pedal. |
![]() Join Date: Apr 2010
The Damper box is right by the clutch slave, teathered to the frame on the passenger side
First thing you should do is pull the trans and find out what you have in there for a clutch / pressure plate... no amount of speculating is going to help without that knowledge... |
![]() Join Date: Jan 2007
im surprised no one noticed the threaded rod on the slave cylinder and the fluid associated with it.
93 s13 Vert - 2jz/cd009 -- parted/sold 95 Supra Turbo |
Had the same issue. Bought the nismo secondary clutch cylinder. Problem fixed.
Here's the thread. #/f/s-chassis/422365...-too-hard.html Last edited by starplatnumm; 12-20-2011 at 09:38 AM.. |
#11 | |
Darren: i know what you mean but my question was if anyone has ever experienced a hard pedal due to master or slave. but thanks for advise, I do want to take it remove trans was just hoping i wouldn't have to ![]() starplaynumm: thanks man, ill look into those if all else seems ok |
#12 | |
