![]() Join Date: Sep 2005
Trader Rating: (48)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 48 reviews
Im having a reving problem after my five speed swap.
My car limits me under 4k. It cuts the fuel and bogs down. I think it might be related to this posting( #/f/tech-talk/174903...st-5k-rpm.html ) Read the number 5 posting and on. I believe I have the wrong speed sensor for my tach. My speedo is not working for one thing, and my 5th and neutral switch are not wired in to add to it. I was told that I did not need to wire in those two switches in order to run the car. Does anyone know if that holds water for certain ? Because before my five speed swap my sr was an auto(ha-ha... I know, it was cheap) and did not have any issue reving. It would go all the way to 7k with no prob. So can anyone help me out ? And please dont tell me its the maf. I have read enough other postings on this issue to rule out the maf.
![]() Do you suffer from vaginal dryness... |
#3 | |
![]() Join Date: Jul 2008
pblesh, its the maf dude...
haha jk man. i know someone would say it, i'd figure i'd say it first. ![]() -makua[ace]
Trader Rating: (48)
All the tech threads and write ups that I read said you can use the auto ecu on a s13 5 speed swap.
So im still using the auto ecu. Does anyone know 100% whether or not you can use a auto ecu on a manual s13 blacktop ?
#5 | |
Trader Rating: (48)
No check engine lights and everything else is normal.
I thought that s13's were before obd1. Where do you plug in a scanner to a s13 ?
S13's are OBD1, OBD2 didnt happen till 1996 and up. Alot of your questions can be easily found in a FSM(Factory Service Manual) Im not sure if it would work depending on how you did your wiring.
