1995 S14 ABS 4 lug to 5 lug conversion
1995 S14 ABS 4 lug to 5 lug conversion FRONT!!!!!!!!!!!!!
Facts: - I want to keep the ABS (just bc i want to!) - Regular S14 non abs hubs wont work (p/n:4020065f50) - I know what to do in the rear. - The Aftermarket that i know just make hub for S13s or regular S14s - im almost sure that the spindle is different from the non abs s14. - I know the best solution is find a donor car with abs and 5 lug. Now: - the part number for the s14 abs hub is 4020067F50 (402000v010) - Any one can help me find out if the J30 hub will work? - Any one can help me find out the part number of the J30 hub and spindle - Any one can help me find a s14 abs 5lug for a fair price - Or what other optios may i have? |
Are you sure that the nonABS and ABS models are different? i dont see how the 5lug hubs would affect anything. They are all the same as long as all you do is change the hubs. I just did my 5 lug on my 14.
#4 | |
![]() Join Date: Dec 2002
The ABS ring for the front hubs is pressed on to the back of the hub, a non ABS hub won't have the ring and is therefore useless. The J30 parts will not work. The S14 ABS front spindle is different, it's drilled to accept the ABS skid sensor. If you already have ABS simply buy a new pair of 5lug ABS hubs from the dealer, remove the old one, slide the new one on. Done.
