5 lug s13 conversion hubs, ISIS vs. Ichiba
As title, im looking for 5 lug s13 conversion hubs (fronts only), as i have modified S13 knuckles but 5 lug wheels to fit.
Previously i used S14 knuckles with oem S14 hubs, but yeah, now i'll be using modified S13 knuckles so need a 5 lug conversion hub/bearing. So, been doing some research and saw ISIS make some and so do Ichiba, does anyone have an input on which i should go for? Isis seem to be cheaper.... Any advice would be helpful! Thanks
https://www.facebook.com/thrwdown?fref=ts |
![]() Join Date: Nov 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 12 reviews
ISIS, Ichiba, Ebay, all the same crap, either get s14 Modified knuckles and OEM Hub or buy these
http://www.frsport.com/Attain-KS-740...-_p_15416.html
I picked up the Tomegun 100$ 5 lug hubs from ebay about 2 years ago. When they came in, I tried to install and noticed a grinding when rotating them by hand. Ends up the circle clip needs to be taken off your OEM wheel hub and put on the Tomegun hub for it to clear properly. I changed the clip and pumped them full of moly grease and put them on the car. Never had an issue, squeak, grind, or anything of the sort ever since install. Always get rid of cheap Chinese grease in your bearings, this is the #1 reason for failing ebay bearings.
The car is a S13 that I daily. Probably ~30-40k since install. |
