#3361 | |
![]() Join Date: Sep 2007
Trader Rating: (25)
Nope, that definitely looks dumb.
#3365 |
Set of knucks i made a few weeks ago. Very short tie rod pickup with huge reduction in ackerman and bumpsteer correction. This is my first set and i am pleased with how they turned out. Next set will be made with roll center correction as well.
As of now my 16x8 0 offset hits the tension rod at full lock with the leading wheels tie rod hitting the control arm. This is with stock s13 lca's with lengthened tein inners and 7mm rack spacers. ![]() |
#3366 |
![]() Join Date: Nov 2009
Trader Rating: (42)
![]() Feedback Score: 42 reviews
So I have plenty of fabrication experience and work as a fabricator at a hot rod/ nascar shop. Have a personal miller ac/dc tig welder and would like to get into modifying front knuckles. I'm decent with suspension setups as I build custom ones at work but what are some pointers?
SW Fab |
#3369 | |
Also, does the wisefab kit not work with fenders or something? Every E30 or other BMW I've seen with the kit doesn't have fenders. |
#3372 |
Hmmm.
Maybe fender interference varies by Chassis? I think that's the first E36 I've seen with Wisefab gear. |
#3374 | |
It's an interesting kit though, its basically a copy of Nigel petries early knuckle ideas which he gave up on, because of flex among other things! More angle the better. Haters need to try it out before hating imo.
[SIGPIC][/SIGPIC] |
#3375 |
I like the idea off being able to "bolt on" the kit to your stock knuckles. I don't really like the cnc'ed lower control arm or the lack of sai. Didn't psm try that and end up with a lot of binding? I'd also like to see some overcentering shots.
#3376 | ||
![]() Join Date: Nov 2005
And this, from what I can tell, bolts to the bottom of the knuckle through the LCA and tie rod holes, and re-locates them. This is a just a educated guess based on the BMW kit and the one tiny shot you can see the parts. Very different from Nigel's, which was a thin steel piece bolted under the front hub. Quote:
Have you guys watched their videos? I hold high hopes based on those. The BMW kits have good self-steering, and massive, smooth angle. We'll see eh? ![]() |
#3377 | ||
#3378 |
![]() Join Date: Jun 2007
![]() ![]() ![]() ![]() ![]() Feedback Score: 22 reviews
Is this normal, or is it an issue? Looking at the tie rod boot, I see the shaft from the rack bending up and down, especially when getting close to full lock.
When the tire hits the tension rod it bends a lot, I need to adjust stoppers to prevent tire hitting tension until I get new tension rods. ~mods angle spacers on both sides stock s13 inner and outer rods knuckles 7* ackerman if I remember correctly, bump steer dropped 1in, shortened. rack moved 1in forward |
#3379 | |
![]() Join Date: Nov 2007
![]() ![]() Feedback Score: 2 reviews
I don't see why you guys hating on a complete bolt on kit that has a lot of improvements for a drift car, where every part of it is designed to work together. This is wonderful, but I think it will be as expensive as the BMW kit, a 950€ plus vat (20% in Estonia). I'll post more info as it is released Last edited by Motary; 11-27-2011 at 04:48 AM.. |
#3381 |
The ball joint doesn't retain the same angle as the stock arm. That's the SAI right? I can't remember what it's called; KPI? PSM had something similar with their prototype arms, but I thought I read Dan say something about having to angle the balljoint bc of some binding issues.
#3382 | |
#3384 |
Not really applicable to FD, you cant use insane angle in a competition because you cant disrupt the speed without getting docked major points.
Backwards entry contest...by all means...you DO need 65* and zero ackerman. Im not understanding what the fuss is about this new angle kit coming to market. You guys do realize that the drift car does need to grip drive some corners in some circuits to build up speed for the drifting section of the course? You need some ackerman. I personally never hit my steering lock while drifting a course, I do when I am trying backwards entries. So you can get today from Parts Shop MAX up to 62 degrees of angle and the lowest usefull ackerman down to 9.5% difference at lock, 45mm roll center correction, OEM bump steer, quick steering....For $400 Or a kit that may cost $1200 to get a few more degrees angle, zero ackerman plus 11 more mm roll center? If the second option is what makes your heart pump guys, if seeing zero ackerman really makes you want to throw 3x the money at a kit that does that, let me know and I'll totally make this happen for you. Now let me hit you with some knowledge about a must have new product that will NOT break your bank: MAX Steering Rack Eccentric Bushing (SREB) set is finished testing and now in production. ~ Price is $50 with free shipping world wide in January (paypal [email protected] to reserve your set) ~ Production parts will be anodized gold aluminum ~ Prevents over centering of tie rod and knuckle to prevent heavy steering at lock ~ Takes ackerman curve from digressive to progressive difference while decreasing overall ackerman ![]() So why is the progressive ackerman better? Its because you get a slower increase in ackerman towards lock, and a quicker ackerman increase on more modest steering inputs. In other words, your low steering input on a GRIP corner will receive the ackerman it needs and the DRIFT steering angle gets less ackerman per steering degree towards lock. ![]() ![]()
How To order: You can order directly from our zilvia advertiser threads. When you add to cart, you get an instant shipping estimate, & the cart will remember all of your items as you move between forum threads and our website www.poweredbymax.net until you remove them or check out. I can also calculate estimates manually for you but the cart's estimates are way faster and more accurate. Order Inquiry: IM me your real name and paypal address. Thanks for your business! Last edited by DC Dan MAX USA; 11-29-2011 at 03:33 AM.. |
#3385 |
Dan, what effect would the steering eccentric spacer/bushings have on a grip car with stock knuckles? Do you feel that the ackerman is well set up on a stock car for grip?
BURN OUT IN YOUR FACE! 1998 S14 LS7/T56 swap in progress, build thread: #/f/tech-talk/147301...d-gto-pan.html |
#3386 |
![]() Join Date: Jul 2005
Damn it! I just did my steering rack and bushings, I wanted some metal ones but the URAS ones were too expensive to justify. So do these slightly space the rack a little more forward?
![]() Instagram - SJKnoop |
#3387 | |
Also, thank you for sharing the effects of the steering rack relocation! I've never seen that recorded, and it shows that you are doing proper R&D on your parts. Do you mind if I use your pics and diagram in the original post of this thread? I can even quote your post if you'd like. |
#3388 |
Sic, the stock ackerman is good for traction during regular steering, and reduced ackerman knuckle and rack position is good for countersteer. Your grip car can take advantage of the MAX roll center only pro grip knuckle.
I have been sitting on this data for a while because I thought it would be more interesting to take the time to provide comparison test data from multiple setups for debut but y'all were calling me out, lol. It does move a little farther forward than the URAS rubber SREB. Please feel free to repost, it is defenately something no one has ever done before.
How To order: You can order directly from our zilvia advertiser threads. When you add to cart, you get an instant shipping estimate, & the cart will remember all of your items as you move between forum threads and our website www.poweredbymax.net until you remove them or check out. I can also calculate estimates manually for you but the cart's estimates are way faster and more accurate. Order Inquiry: IM me your real name and paypal address. Thanks for your business! Last edited by DC Dan MAX USA; 11-29-2011 at 12:18 PM.. |
#3389 | |
![]() Join Date: Oct 2007
#3390 |
![]() Join Date: Nov 2004
Those things are cool.
Who knows if I need them or not. But for the price it's awesome. Gotta get me some of those and some PBM offset rack spacerssssssssssssssssssssss
| anti-squat, best thread ever, kpi, roll center, steering angle, suspension |
