![]() Join Date: Aug 2006
Trader Rating: (105)
![]() ![]() ![]() ![]() ![]() Feedback Score: 105 reviews
I am parting out a great condition s13 blacktop sr20det. The motor was running well before being dismantled. The reason it was taken apart were intensions of building it to hold more power. I don't have time to build a motor right now, so all parts are up for sale. This entire motor is very clean and no parts are damaged. I have all bolts and small parts bagged and labeled.
If you see anything you are interested in purchasing post reply or PM me. All prices do not include shipping, please leave zip code for quotes. Long Block: Valve cover (one broken tab in rear, good for s13.4 cover)-$50 Blacktop head w/ cam caps, valves, springs, retainers, and seals-$250 OEM cams-$70 for pair Cam gears-$30 for pair Rocker arms-$80 for all 8 Lifters-$80 for all 8 Shims-$20 for all 16 Oil feed tubes-$20 for pair Head bolts w/ washers-$20 for all Timing chain tensioner-$40 Timing chain-$20 Timing chain guides-$20 Lower timing gear-$10 Block-$300 Crankshaft-$200 Rods w/ ends & bolts-$80 all 4 Crank girdle -$30 Windage tray-$20 Upper oil pan-$60 Lower oil pan (small dent)-$20 Oil strainer-$20 Rear main seal w/ housing-$15 Oil pump spacer/collar-$10 Crank bolt-$8 OEM cams-$70 ![]() Oil feed tubes-$20 for pair ![]() All bolts bagged and labeled ![]() Oil sandwich plate-$30 Flex plate-$40 OEM flywheel-$50 Flywheel bolts-$30 for all 8 Sr20 Exedy stage 1 clutch (lightly used)-$60 Sr20det transmission w/ all sensors-$290 ![]() Sr20det starter-$80 Ignitor chip-SOLD Redtop #62 ecu (works with blacktop)-$100 Coil packs-$70 for all 4 Crank angle sensor-$100 Knock sensor w/ harness-$30 Oil strainer-$20 ![]() Water outlet w/ bolts-$30 ![]() Water inlet w/ bolts-$20 ![]() Thermostat housing w/ bolts-$20 ![]() Brand new OEM Thermostat-$20 Temp sensor housing-$20 Temp sensor for gauge-$10 Temp sensor for ECU-$10 Temp sensor harness-$15 S13 intake manifold-$50 ![]() Intake manifold brackets-$20 for all ![]() S13 throttle body w/ auto TPS-$50 ![]() 370cc Injectors-SOLD Fuel injectors caps w/ screws and washers-$5 each S13 fuel rail-$25 SR20 fuel pressure regulator-$25 Lower oil pan w/ small dent-$20 Complete alternator bracket w/ bolts-$30 Engine mount brackets-$40 ![]() OEM turbo elbow-$20 T25 turbo outlet-SOLD Aftermarket Parts: Godspeed Gt3076r turbo w/ wastegate (used few hrs.)-SOLD Goodridge water return line-$40 3" turbo elbow (used few hrs.)-SOLD ![]() 3" down pipe ( used few hrs.)-$60 Oil feed banjo bolt-$10 T25 oil restrictor-$10 ![]() Turbo gaskets-SOLD CXracing hot pipe with wastegate nipple-SOLD CXracing 2 piece cold pipe (brand new)-$50 Steel cold pipe painted aluminum-$50 ![]() Q45 MAF-$50 Nismo SR/KA thermostat ( around 4k miles)-$40 Peak Performance transmission mount w/ hardware-SOLD Thanks for looking, let me know if you need anything.
PM me for s13 or s14 parts! Last edited by s13 drifta; 01-30-2012 at 07:23 PM.. |
![]() Join Date: Dec 2011
What condition is the timing chain in?
And is that all I need to replace my old timing chain? My car back fires lol
1995 S14 Zenkei SR20DET Blacktop Wrecked! |
#4 | ||
If your timing chain is loose I would recomend replacing the guides and tensioner as well.
PM me for s13 or s14 parts! |
#9 | ||
I would like to sell all lifters together as a set, unless I have a buyer for the rest. Do you need the P/S banjo bolt? I have a clutch fan from a ka24de that I modified to fit a sr20 if you are interested. Quote:
I don't have a throttle cable bracket, let me know if you need anything else.
![]() Join Date: Feb 2008
Yes, i need the p/s banjo bolt. How much shipped to 53223?
[QUOTE=s13 drifta;4453137]I would like to sell all lifters together as a set, unless I have a buyer for the rest. Do you need the P/S banjo bolt? |
#27 | |
$300 shipped with insurance.
Thanks, took me a whole day to post everything. Quote:
No, just some small pieces.
