![]() Join Date: Aug 2010
My unknown short/drain
Hey so my dilemma is pretty simple. When I go to crank the motor with the key it just ticks and hesitates multiple times. I have a brand new starter. And I took off the ignition just to double check that it wasn't that either. The car was previously automatic but swapped to 5-speed. That was done almost 2 years ago
Get a multi meter
1) voltage across battery 2) voltage at starter (big wire) to a known good ground We need more info
@UpshiftEngineering |
![]() Join Date: Dec 2004
Trader Rating: (58)
Is the battery itself good?
All I hear is the clicking from the solenoid popping. I bought a brand new 4 gauge cable wire from oreilys last night and bolted the other end from the battery to my firewall by the vin number. But as I go to turn the key. The started just clicks really fast. I feel like Im close to solving it but yea I have no volt-meter to measure the ohms and such it got stolen.
I was reading on someone's else's thread that my solenoid isn't grounding and to try to move my bolt to the intake manifold. But my starter is also new I bought it yesterday. |
get a DMM...go to harbor freight buy that shit for 4$
otherwise this thread is useless...test battery first as i and Cody stated.. get back to me and i will continue to help..you cant prove anything (realistically) with out a DMM
