#1294 |
![]() Join Date: Jan 2005
Nope...I TIG some of the parts on the S14 TC brace, and I was going to just do the top of the gusset to the crossbar on this one. I just got carried away...lol. I need TIG practice, so I just did this bar...lol.
#1296 |
Origin Lab Fiberglass Door "Re-enforced Aluminum 6160 Plate". This will take the load off the fiberglass when adding the glass and components back into the 10lb door.
[IMG] [IMG] [IMG] Scott |
#1300 |
![]() Join Date: Dec 2002
Wow how does that thing fit in a trailer? its like wider than the road.
Really cool you got to check it out in person. anyways. Lets try and keep this to projects we have done. MODS: please remove the lexus race car post.
#1301 |
![]() Join Date: Aug 2007
So I cut my front wheel wells out to do it in sheet metal vice a stack of fiberglass. I was planning on using 1.2mm thick sheet. Should I use that or go with something thicker or thinner? I am sorry if this post is out of line Blu808 but I promise to post results in return as I have some pretty sick ideas that I plan to incorporate as well.
#1302 |
Brian - 1.2mm is pretty thin, but it's not load-bearing. As long as you "wrap" the edge (curved part has a 90* joint with the straight part, and that's where you rivet) the edge should hold the shape.
Here's a super quick Pshop I did.
#1303 |
I could go with something a little thicker, but I was worried abotu the ability to get the gradual bend need for the well. Also, would you still tab it like this if you were going to weld it?
#1304 | |
I don't know its late.
#1305 | ||
![]() Join Date: Sep 2004
FreshAlloy.com Forums specifically pay attention to this picture... that piece of metal that wasn't cut under his green tape is slit into tabs and folded up for the spot welds on the bottom of the metal to support the tub up top.
Wayne |
#1309 |
![]() Join Date: Jul 2006
my "oem" style fender tubs.. im not done at all yet but i move it up just over and inch and extened forward about 2inches. used my 18x9.5 +22 SA3r with 275/30 RT615s as clearance check
#1311 |
Yeah Vaughn does good work - that's what I was trying to tell ya to do
![]() Yup - I bought a bunch of 18ga in a 2ft-wide roll do to splitter/ducting work years ago, you could definitely get it to do tubs as long as they're not load-bearing. It's pretty stiff when you do the sides like that - and it's easy as shit to weld (compared to thin lil aluminum).
#1312 |
![]() Join Date: Mar 2003
My apporoach was similar i cut the factory well and pulled it out about 3 inches and gave tons more clearance no rubbage with 275/30/18 . I would have tubbed but i ran out of time and this was the most elegant solution i could come up with at the time.
ANTI-STRETCH NAZI Vortech Supercharged Vh45de S14 V8nissans.com |
#1313 |
I hate the factory "ribs" in the fender tubs so much that that's what I would want to get rid of the most.
I'm picking up my welder this week, I'll probably do tubs next week just cuz.
#1315 |
Admin Asshole
![]() Join Date: Mar 2002
While we are breaking up the mini-tub party, allow me to pose this question...
What do Zilvia's master fabricators think of something like this? East Coast Corvette: 1997 & Newer C5, C6 and Z06 Corvette Performance Parts & Accessories. Odessa, Florida Now, I understand a large cross section of Zilvia won't give a damn about scraping up their front, because they don't really care about their cars anyway. For those of us that do care, what do you guys think? Looks like it shouldn't be too terribly difficult to fab. I think it would be all about positioning it to be useful, and then bracing it to support the weight. Thoughts? Has anyone fabbed something like this before?
"Speak softly,..." -Pres. Teddy Roosevelt "Be polite, be professional, ..." -Gen. James Mattis |
#1316 |
How's it connected to the frame? The 2" angle stock is welded to... what?
Need moar pics!
#1317 | |
That's where my dad bought his supercharger stuff - I've met the guy a few times. I've thought of doing exactly the same thing, but Corvettes have a nice beefy frame up there (because the radiator sits "tilted back", resting on this substantial crossmember between the "frame rails") and these cute little runners that go out from underneath the rad support to the bumper support. Our cars don't have any substantial frame pieces that far forward. I thought about including something like that if I ever did a "bash bar" that went that low - but yeah, the wheels have to be on the leading edge or they're not doing anything. I'll take some pics of the Z06 next time I'm over at my pop's place, and you'll see what I mean.
#1319 | |
![]() Join Date: Oct 2006
Welding galvanized is really dangerous. The fumes given off while welding are highly toxic. This is caused by the galvanization process. Make sure you are in a well ventilated area and wear a respirator.... When I say this shit is toxiz. It's really bloody toxic. Can can a whole heap of problems... |
