Rb25det neo 2
So I got a 240sx with a rb25det neo 2 and I need help with the after market manifold Intake I install, I cant get the idle to work proper it shots off when i try to drive the car the idle goes down and car shots off, any body that can help me i appreciate...
![]() Join Date: Jan 2010
how about some English first please???
#3 | |
LOL
Are you positive your engine is a NEO? There is no NEO 2 version of the RB25det. There is a series 1, series 2, and NEO RB25det. If it is a Series 2 and not a NEO, then you should have the right IACV valve for the Greddy type intake manifold, if you are replacing the stock manifold. If you have a NEO, then the stock IACV will not fit the cut-out and mounting location on the underside of the Greddy manifold. I would then suggest purchasing a B13 Sentra IACV, from the 1.6 liter, which is the same IACV as the RB25 Series 2, minus the T on the air inlet (not really needed). It is a lot cheaper than buying the S2 IACV. What do you have for tuning? The IACV can be blocked off, though I would not suggest it, if your tuning can compensate for the lack of air with no throttle input. |
