KA24 Transmission Select Plunger?
Where can I source out the plunger that goes inside the transmission on the sides of the shifter. I had one side pop off so I lost the Plunger, Spring and Bolt.
I can probably get the spring and bolt online somewhere but I cant find anywhere to buy the plunger. Any links to sites would be awesome. Thanks in advance |
what? Are you talking about the slave cyl, the shifter fork or the clip that holds the fork on or what?
Oh wait, are you talking about the shifter return springs? that return the shifter to center/neutral? |
