| USA Talk to others in your region. |
![]() Join Date: Nov 2001
Denver guys and girls Auto cross at Coors Field Feb 16th
I was just told there is an Autocross at Coors Field on Sunday Feb. 16. I'm told there will be at least 2 other 240's there and I'll be there and might be running for the first time. Spectators are free and I belive but I'm not sure that it cost $45 to drive. If your interested register here www.rmsolo.org
Looks like alot of cars are registered so it should be fun if it's not too cold. Garrett
1989 240SX Coupe -Eibach Prokit Springs -KYB AGX Struts -Apex-i N1 Dual Exhaust Westminster, CO |
I'll definitely try to make it out there. Doubt I'll run, cause I need new brake pads and my tires are bald, but I'd like to check it out and most likely run next time. See you guys there, if you make it. I'll be in a white s14 base...
