#61 |
![]() Join Date: Dec 2008
Trader Rating: (79)
![]() Feedback Score: 79 reviews
Thanks I try my best with my time & money, but I recently lost my Grandfather & havnt been movtivated to work on the car thats why I havnt updated anything
My Build: The "Coupe De Ville" 1JZ Build!! |
#63 |
Trader Rating: (79)
Thank you for you condolences, I know he would of liked to finally see it run....But goodluck on your swap there a endless money pit
#64 |
Trader Rating: (79)
UPDATE
SINCE I BOUGHT A GENUINE OEM GASKET SET I RECIEVED NEW INJECTOR O-RINGS SO I DECIDED TO INSTALL THEM OLD VS NEW I ALSO INSTALLED NEW CAM SEALS, A NEW PILOT BEARING, AN NEW FRONT & REAR MAIN SEALS AS WELL OLD VS NEW REAR MAIN REAR MAIN INSTALLED! NEW PILOT BEARING MAACO TOOLS ARE THE SHIT! IT WORKED PERFECT TO REMOVE THE PILOT BEARING (ALSO THE ORANGE BEARING IS THE NEW ONE JUST FORGOT TO TAKE A PIC OF REMOVING THE OLD ONE) ALSO CLEANED & SANDED THE CAM SEAL SEATS OLD VS NEW INSTALLED! FRONT MAIN WAS BEHIND THAT SPROCKET ALSO CLEANED UP THE REAR CAM GEAR COVER & PAINTED THE TENSIONER SINCE THEY WERE WAS OFF AFTER ALL THE NEW SEALS & BEARING WERE FINISHED I INSTALLED MY NEW BANDO TIMING BELT, DRIFTMOTION V.2 PULLEY SET & NEW PULLEY BELT I ALSO MADE A BLOCK OFF PLATE FOR MY STOCK BOV SINCE I WONT BE USING IT & THE COMPANY I WAS GOING TO BUY IT FROM STOP MAKING THEM? I PICKED UP A FLAT PIECE OF STEEL ABOUT A 1/4 THICK FROM LOWE'S & CUT IT UP TO THE SHAPE OUT OF THE OUTLET..ITS SORTA A "PROTOTYPE" SO WILL SEE IF IT LEAKS OR NOT? SO WILL SEE HOW THAT GOES & THE BOV THAT I AM GOING TO GO WITH IS A OLD SCHOOL BLITZ SUPER SOUND, MY BUDDY HAD ONE ON HIS MR2 & IT SOUND GOOD SO I FOUND ONE HERE ON ZILVIA FOR A GOOD DEAL I ALSO CHANGED THE GASKET BETWEEN THE BLITZ BOV & FLANGE WITH A NEW DIF GASKET STAY TUNED FOR MORE!
#67 | |
Trader Rating: (79)
Yeah definitely will be updating it weekly for a while stay tuned
#68 |
Trader Rating: (79)
UPDATE
Ok well I finally got around to mating the the 1J to the R154 So I already had the USDM Supra R154 & JDM JZ Bellhousing so all I needed was a Clutch Kit Well browing through supraforums.com I found a USED "Discontinued" TRD 1JZ Lightweight Flywheel (which is 24% Lighter than stock) for a awesome deal & the guy also happen to have a USED TRD 1JZ Pressure Plate which is Basically a Stage 3 PP too so I just bought both I also took a trip to Driftmotion & bought a BNIB ACT Xtreme 6-Puck Stage 3 Clutch disc, BNIB ARP Flywheel bolts, NEW PP Bolts, NEW Bellhousing to Engine Bolts, BNIB Aisin Slave Cylinder, OEM BNIB Throw Out Bearing & NEW Clips & Retainers for Clutch Hub & then the fun began! Was happy with the outcome. The only problem I had that I came across was with the R154 you have to first put the Clutch on the tranny first & tighten everything through the Inspection Covers not install it onto the engine first Like Nissan Tranny's....& also all the bolts were toque'd down to OE Specs
My Build: The "Coupe De Ville" 1JZ Build!! Last edited by jdm2191; 08-06-2012 at 02:10 AM.. |
#69 |
![]() Join Date: Feb 2010
Why can't you install the pressure plate the normal way? I installed my 1jz pressure plate like I would a Nissan. I think Toyota did that to service the clutch easier in the supra. There is no need for an alignment tool if you install it like a torque converter on an auto car. My SPEC clutch kit came with an alignment tool which puzzled me until I tried installing the clutch like normal.
#70 |
The only thing I had to remove, to pull off the tranny, was the clutch fork and slave cylinder. That bracket that holds the fork in place doesn't have to be removed either since the fork just pops out of the bracket; after the slave cylinder is removed.
#71 | |
Trader Rating: (79)
#72 |
Trader Rating: (79)
SMALL UPDATE
Well I been busy on finishing up my Wheel Tubs & finishing my Fuse/Relay Box Relocation, but in between then I have picked up a few parts I picked up this Tomei Trax 2 Way Diff off Dreezed here on Zilvia....Still need 5 Bolt Axles so PM if you have a Pair for sale Also bought a RHD S13 Throttle Cable because it is shorter then the USDM one since the 1JZ Intake Manifold is on the Left side. Still need to make a bracket for it, but will get back to it in a Future Post I was missing the front engine hook on my 1J so I bought one on the supraforums. When I recieved it it was dull & faded so I bought some VHT Black Wrinkle spray paint at Auto Zone to test it out & see how good it was... They didnt come out to bad actually, So I will definitely continue to use it Took a drive out to FRsport & picked up a DIF Steering Bushing, hope I feel a difference Lastly I ordered my trailer fender for my wheel tubs! Was pretty happy for this!
#73 |
I'm still curious why Toyota instructions for the clutch are like that. Any light shed on the topic would be helpful. Whats next on the build?
#74 | |
Trader Rating: (79)
But the next main things on my list is -Finish Tubs -Paint Engine Bay -Buy Actual Motor/Tranny Mounts -Get custom XRP Fuel Lines -Buy a Clutch Line -Buy Radiator/Fan set up -Get a few new connectors for Harness (few of them cracked) & Ill be in good shape ![]()
#76 |
#77 |
Neat Built, I like watching other 1J's go together.
Two things: -Your BOV blockoff plate should work just fine. That port only ever sees vacuum, so it doesn't need that crazy of a seal. -Did you really need a new throttle cable? I'm using my stock SOHC KA one - all I needed to do to make it work was move the throttle cable bracket back by one bolt... It is a hair long, but nothing unreasonable. |
#78 | ||
Trader Rating: (79)
The Nissan way would probably work but it was a pain in the ass Quote:
#79 |
Trader Rating: (79)
Need some input on what damn color I should paint my engine bay??? It's driving me crazy!!
Im undecided if I should stay with the OE Misty Blue Metallic or something different? White or Black or another color that mathces my OE Color? Hard Decisions haha This Pic was a few months ago before I rattle canned it black to see how "good it would look This is before I started on the wheel tub job
#80 |
![]() Join Date: Apr 2007
Don't do it black, I find that alot of stuff get's "lost" in a black engine bay. I love a white or silver engine bay as alot of the colors pop. But i stay go OEM.
clean build as always!
#81 |
Trader Rating: (79)
Yeah that's true about Black. I actually wanted to do Black with maybe some Silver flake because my car almost looks like silver & I like White it will definitly POP, but would have to be cleaned more often. With Silver I feel like it will look like I was trying to match it with my OE Color but didn't quite get it, but I guess Misty Blue Metallic it is! I just don't know how much paint to get for a Engine Bay?
#83 |
Trader Rating: (79)
thanks bro I have a update coming soon
#85 |
Trader Rating: (79)
Updates soon! Going to order my Motor Mounts & paint for my Engine bay this weekend
#86 |
Trader Rating: (79)
UPDATE
So I got a few thing done nothing major & have picked a few goods I finally installed my DIF bushing, it gave more trouble then I assumed lol but I got it! My old bushing wasnt in to bad of shape but im glad i changed it for a solid one Also started messing around with my LEDS for Tailights. The first section came out a little bit to tall to fit into the tailights but atleast I got a feel for it Since im going to be running a KA/RB Radiator I needed to cut my waterneck So I could run a smaller Radiator hose, instead of running a long hose along my cams with a Supra or SR Radiator which I think looks kind of dumb Some might call this Ghetto or Creative but hey what can I say I make things works lol I bought this Front Sump Dipstick off a member here & its off a JZX100 VVTI because mine was from a Rear sump & wont read correctly & there pretty hard to track down but its from Front Sump so thats all that matters. The only problem is that the handle was broken off so decided to make one from a key ring I then sprayed it black til I get some yellow paint Also cleaned my Bride seat. Its a Bride Zeta III SPORT (Non-FIA Approved) that why it has a BLACK back & not a SPARKLY back. Its more of a Street Seat All this stuff shows that its the real deal BEFORE AFTER It also has Bride FG Seat Rails ![]()
My Build: The "Coupe De Ville" 1JZ Build!! Last edited by jdm2191; 09-12-2012 at 01:51 AM.. |
#89 |
Trader Rating: (79)
Im trying bro, thanks
yeah good ol' steam cleaner & some elbow grease
#90 |
![]() Join Date: Aug 2009
Trader Rating: (55)
![]() Feedback Score: 55 reviews
dayum man, lots of progress, lets see them tail lights when theyre all finished whats the total cost on parts for them? If it's cheaper than 400 bucks I'd consider doing them myself.
