SR20DET estimated power + max boost?
Hi everybody,
I bought an s14 few months ago, and I interested to know my estimated power. Car specs: S15 engine with GT28R 740cc injectors tubular Manifold Greddy inlet manifold 2.5" piping 1.5 mm head gasket Power fc ECU External wastegate Low-weight Pulleys The car runs with 1.5 bar of boost -What is the estimated power for this spec? -One more little question: How much boost the original pistons and rods can handle? Thanks ![]() |
![]() Join Date: Mar 2011
damn son 20+psi of boost.... i wanna say prob around the low 300s to mid 300s
stock bottom end is good for around just over 400 but i wouldnt go bouncing off the rev limiter with that kind of power on stock bottom end parts haha |
![]() Join Date: Nov 2010
i put down 300 with mods in my sig. So with better turbo and higher boost. ud be mid 300s with 91 oct.
![]() Join Date: Apr 2004
Turn the boost down. Past 16-17 psi that GT28R is just blowing hot air towards redline.
That turbo is good for 300 rwhp give or take a little.
#9 | |
![]() Join Date: Jul 2008
Trader Rating: (32)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 32 reviews
should be about 290ish |
Thanks.
Last question: For everyday drift car with some track days. Can be any problem with the fuel flow to engine when drifting without surge tank? Or i must install an surge tank before drifting? |
![]() Join Date: Jan 2008
people use the gt28rs, seems like a great turbo for 300-350 range
My Twin Scroll Gt30r Sr22det Build |
#17 | |
![]() Join Date: Jul 2005
Rephrase of this (with my own opinions included) : Turn it down to 16psi if you want to get 50% of its life expectancy turn it down to 12psi if you want to get 95% of its life expectancy "it" = S15 turbocharger oil seal max power I have ever seen one of those brand new make is 318RWHP that was around 17psi. Most will peak around 290RWHP on average though, you are lucky if you get any more than that (luck = cold weather) Over the years after countless experiences with countless S15 engines I have concluded that "it" was not designed with 15psi+ In mind. You can still tap the compressor with 12-13psi if you know what you are doing (what you are doing = valve timing) |
