![]() Join Date: Feb 2002
*NOW IN STOCK*
![]() __________________________________________ NRG Innovations has developed a new line of Radiator Diversion Panels. These units maximize the cooling capabilities of the radiator. Rather than letting air escape through structural gaps on the vehicle, it is redirected into the radiator. By increasing the amount of airflow passing through the radiator, the efficiency of the radiator is improved. Coolant temperatures are kept consistent under all driving conditions. The panel is easy to install using standard hand tools. The Radiator Diversion Panel is made from 1mm thick rigid stainless steel plate, precision laser cut brushed finish prevents overheating under extreme driving conditions. Motorsports functionality with show quality looks. __________________________________________ Click here to order ===> http://www.enjukuracing.com/products...s14-95-96.html
