| Group Buys Dedicated Forum for Group Buys. |
Mazworx SR Head stud/main studs
THEY ARE NOW INSTOCK!
We are proud to introduce our line of head studs and main studs for the SR. We have to come to realize that the engagement on the ARP off the shelf ones dont thread into the block completely and not bottoming out so it does not giving enough grab. So with these we developed will be the correct length and actually stronger and better material. ARP current head stud/main stud 8740 CHROME MOLY: Until the development of today’s modern alloys, chrome moly was popularly considered a high strength material. Now viewed as only moderate strength, 8740 chrome moly is seen as a good tough steel, with adequate fatigue properties for most racing applications, but only if the threads are rolled after heat-treatment, as is the standard ARP production practice. Typically, chrome moly is classified as a quench and temper steel, that can be heat-treated to deliver tensile strengths between 180,000 and 210,000 psi. Mazworx Headstud/Main stud material ARP2000®: An exclusive, hybrid-alloy developed to deliver superior strength and better fatigue properties. While 8740 and ARP2000 share similar characteristics – ARP2000 is capable of achieving clamp loads in the 215,000-220,000 psi range. ARP2000 is used widely in short track and drag racing as an up-grade from 8740 chrome moly in both steel and aluminum rods. Stress corrosion and hydrogen embrittlement are typically not a problem, providing care is taken during installation. Made from ARP2000 material 12 point 220ksi tensile strength Straight shank/bullet ends from complete bottom out Comes with (10) studs, (10) washers, (10) nuts (1) assembly lubricant and instructions. The Mazworx Main Studs WILL CLEAR without upper oil pan machining!!!!!!! Head stud comparison. Std ARP off-the shelf, Mazworx Head Studs, Mazworx 1/2" Main Stud Comparison ARP off the shelf, Mazworx Main We are going to start a group buy on these now, our expected delivery time on these studs is about 6 weeks. Introductory price are as follows: Mazworx Head Stud kit - $195.00 shipped Mazworx Main Stud kit - $195.00 shipped Purchase both together for $370.00 shipped. Please PM us if you have any questions.
www.mazworx.com [email protected] Nissan S-Chassis and SR20 Specialists! *Your #1 source for all engine/machine work.* M-F 9-6pm EST Tel: 407-281-1223 Pro Modified S15 Best ET 7.36 Best MPH 184.00 Sport RWD S14 9.07 @ 155
Pm's replied Thanks!
This is an oem upgrade.
These are for OEM setup. These have more thread engagement than the off the shelf ARP. Its hard to compare a 1/2" stud kit to this or a 400.00 L19 head stud kit. They are do different jobs.
PM's replied Thanks!
Well Shit, haha. I just orderd these a couple days ago from my local shop. They called and asked for a shop discount I think. I paid 206 and some change for the mainstuds for the s13 SR. Not bad though especially for what you are getting. Cant wait for them to come in!
Beeeefy! Its whats for the SR! |
