![]() Join Date: Jul 2008
![]() ![]() ![]() ![]() ![]() Feedback Score: 12 reviews
Metal headgasket
If I use a metal headgasket n lower my compression in my ka-t will i be able to push more boost without changing internals?
![]() Join Date: Dec 2006
400 my ass.. Im not saying it never happened but if it did its a fluk. I love sr to death I know the record is 613 hp on a stock bottom end But i know good and damn well sr's arn't good for 600 .
![]() Join Date: May 2005
Location: Louisiana. LA is for Louisiana. L.A. is Los Angeles.
I've seen KA-Ts get up into the 500s on stock internals. Highest I've seen on the dyno is 576 RWHP.
#/f/sale-items/24807...-stuff-fs.html |
KA FTW! coming from a srowner, rb owner vh45de owner... KA NA! for now.. lol |
![]() Join Date: Nov 2007
As we all know, the more power you make the less reliable the engine becomes. So make power according to your budget. 500plus hp on one run on the dyno is possible but dont expect to push it run after run without seeing things go wrong.
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180 |
#10 | ||
He ran that 576hp KA for quite a while (as far as 500+hp KAs go) before building the bottom end. No, it didn't blow, he just took care of what was needed BEFORE the damage was done.
OK fine 400 is pushing it for the reliability factor but it is doable heres the thread for dummies of ka-t.org....this is like daily driving /beatage if its a track car and used occasional def could do 400
Average: 300 rwhp to 350 rwhp, you have to start to expect a little more lag. This is about the perfect "street car" limit. No race gas, just good honest street car fun that is fully capable of bring home a 12 second timeslip on a good run. Turbo Manifold T3/T04E .50 Trim compressor, .60 trim compressor housing / Stg 3 (aka TA31) turbine wheel, .48 to .63 A/R exhaust housing. Internal wastegate optional but not recommended. Downpipe can still be 2.5", but this is as far as I would want to push that. Front Mount Intercooler (FMIC) It's time to upgrade to a larger front mount as the larger will push more air than the smaller sidemount can cool. Fuel Control 550cc Injectors SAFC2 to control your fuel injectors, along with the stock ecu. MSD BTM At this stage I would be running the BTM to control timing retard. Reflashed ECU-This can be a DIY thing with Megasquirt Tuning or a JWT. Z32 Maf is required, as the stock Maf stops being able to read at around 260 rwhp. Wideband O2 Sensor should be installed for tuning. Block Internals This is where I would start to consider it necessary to replace you pistons. |
