Old 12-22-2008, 07:48 AM   #1
dori_pho
dori_pho is on the path to ruindori_pho is on the path to ruin
transmission is making a violent grinding noise
Hellow im here to see if any one can help me with my transmission problem. Every once in a while when Im accelerating from a light in second gear, my transmission will make a VIOLENT grinding noise and vibration. It is the exact same noise/shifter vibration as if I was jamming it into gear and grinding gears, except it happens for a moment while my car is in gear!!! This is really scarring me, what could cause this. It happened once tonight while I was in 5th gear cruising also. The sound/vibration is sudden and violent, as if I ground gears during a mis-shift. Its just as quick as a mis-shift, but without me touching anything.
dori_pho is offline   Reply With Quote
Old 12-22-2008, 10:59 AM   #2
sillyvia13
sillyvia13's Avatar
sillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfection
Change Fluis ASAP.
you may have a piece of metal broke off in tranny, hopefully it falls out.
I would use GM Syncro mesh fluid too, works well.
gl
sillyvia13 is offline   Reply With Quote
Old 12-22-2008, 01:16 PM   #3
nismo racer
nismo racer's Avatar
nismo racer is making a name for him/her selfnismo racer is making a name for him/her self
That sort of happened to me, it would grind a bit so I flushed the fluids and it was gone so I'd say do that and see if that works. Use redline mt90 it helps
PEGASUS
nismo racer is offline   Reply With Quote
Old 12-23-2008, 02:27 AM   #4
4x4le
4x4le's Avatar
4x4le is an unknown quantity at this point
Send a message via AIM to 4x4le Send a message via Yahoo to 4x4le
yep, just go ahead drain it out, if you dont see any metal come out you can pull the tranny and crack it open to make sure there is no loose metal inside if you want. (im sure you want to go through that much trouble though lol)
Just drain it, and refill it and if it goes away dont worry about step 2.
4x4le is offline   Reply With Quote
Old 12-29-2008, 03:35 PM   #5
thagremlin
thagremlin's Avatar
thagremlin is an unknown quantity at this point
man you just got that car and its already breaking... at least yours runs unlike me
thagremlin is offline   Reply With Quote
