![]() Join Date: May 2009
95 base passenger fuse box issues, I really need help.
Ok so I bought a 95 base rolling chassis and it was missing a few things here and there, Diff, motor, trans, driveshaft, etc etc. Well in the fusebox, one row of the fuse panel is missing. Here is a pic for reference.
Well I had a 97 and I kept all the wiring from it, and my 97 has it. The 97 has a lot of power wires coming out of it that connect to the other panels and some that go into the chassis harness leading around the engine bay. My car, the 95, doesn't have that section of the fuse panel. I don't see any wires that were cut to remove it like you would have to do on my 97 so I"m wondering what I need to do to put this back in my car.... like where the wires go, etc. This is what I'm missing for reference. |
AFC #1
![]() Join Date: Oct 2003
It's on the bottom of the picture of the 95 box. The row below the blue relays.
Boxes changed in 96-97 I forget if it was the obd1 change or the Kouki change. Books are at home.
![]() Join Date: Dec 2002
1995 base models have a different fusebox. The 100A fusible link is not found on them. The 75A is the first circuit inline from the battery.
So, it's not missing, it just doesn't have it. They made the change in 1996 to match the SE models, having the larger 100A and the 75A links.
