07-24-2013, 08:36 AM | #6 |
^^First of all, the 'red gearlike knobs' are there so you can manually move the lights up & down by hand. Spraying them with WD-40 will only clean any moisture-related contaminants off of them.
The screeching you're hearing is either the assemblies binding on the hood (adjust hood position), or the rod-ends etc are badly in need of cleaning/lubrication. To lube, use standard lithium or general purpose grease. DO NOT use WD40 as it is for water displacement (hence 'WD'), not lube.... Easy peasy.
07-24-2013, 11:09 AM | #7 | |
07-24-2013, 11:22 AM | #8 |
Yes. If they're too rusted out, worse case you can either source out new hardware at Home Depot... or just get in there as best you can with a rust solvent & some grease to lube 'em.
