NRG, Nismo, ka-t parts & much more!
NRG stainless radiator cooling panel for 1995-96 Zenki S14- $75 FIRM
BNIB never installed.. only set on the car for picture. Still has white plastic protectant, never removed. Stock S14 Front Brake setup- (4 lug) $100 obo Incl rotors, calipers, lines and I think the pads are there too. OEM KA24de S14 fan shroud in very good condition, no broken tabs or cracks- $30 OEM KA24DE stock Electric AC fan incl good harness- $40 OEM KA24DE Fan clutch and blades- $40 Cleaned and buffed all blades Looks and works great. S14 stock fuel pump- $20 S13 Emance ecu dyno tuned for ka-t.. I drove to Emance and had him personally dyno tune the ecu. made 280whp at 10psi with a t3/t4, 550cc inj, & n62 maf and minor adjustments with an safc neo. Includes ecu and conversion harness for s14 -$300 firm. I also have a set of 550cc Deatschwerks injectors, had them flow matched and tested (I have the sheet with numbers to prove)-$250 firm. SOLDSOLDSOLD!! Stock S14 Zenki amber side markers- $20 Ka24de top mount cast iron manifold new style flanged for a t3 OR t4 turbo-$90 SOLDSOLDSOLD!! NEVER used and NEVER installed. 38mm external wastegate flange. This style sits the turbo further away from the bmc for better clearance..which is a hugee pain in the ass if you use a normal manifold. NO heat shields, NO sock covers and NO boiling your brake fluid with this one Good clearance New Oil cap- $8 Turbo intake pipe with welded 5/8 bung (for valve cover breather) and 19mm-3/4 bung for recirc of bov- $25 FILTER NOT INCLUDED. 2.5" V-band clamp with ss flanges -$25 only used the clamp for almost a week in attempt to seal an exhaust leak..had to rebuild dump pipe instead. V-band flanges haven't been touched. Still in perfect condition. Stock s14 front sway- $10 Four Bronze 8-spoke DLX Hype 4x114.3 18x7.5- includes ONE good Falken tire -$400 *Also have various stock suspension arms- $20 per set Thanks for looking! ![]() Please pm for quick response or txt 909 720 2419
Friends don't let friends build SR20's. Have faith in your KA!! Last edited by dRift_g0ddess; 01-11-2011 at 12:23 PM.. Reason: Sold part |
![]() Join Date: Jan 2007
![]() ![]() ![]() ![]() Feedback Score: 23 reviews
Hi how much for the clutch line and the 14" steel braided line shipped to Phoenix AZ 85033...Thanks......
[SIGPIC][/SIGPIC] http://wheelflip.com/r/Wheelwhore87 |
#13 | |
Sale pending on springs ![]()
Friends don't let friends build SR20's. Have faith in your KA!! |
#15 | |
Injectors have less than 1500 miles on them, and o-rings are NEW, be sure to lube before install though. I have a pretty recent flow sheet from Deatschwerks, I sent them in and paid to have them tested and matched. One was burnt out so they replaced it with a brand new inj, the sheet tells you which one is which. They work perfect, I don't sell broke sh!t.. see trader rating ![]()
| ka-t, nismo, turbo |
