Old 03-24-2015, 07:54 AM   #1
lovethatpssh
lovethatpssh is an unknown quantity at this point
Rb20 boost problem
Was boosting 14 and Boost and vaccum where working fine thenTheexhaust pipe coming from the turbo broke lose got it welded and now no vaccum at all and doesn't even boost 5 psi dk wht else todo
lovethatpssh is offline   Reply With Quote
Old 03-24-2015, 08:27 AM   #2
Mikester
Mikester's Avatar
Mikester is a well-known jackass
Wastegate stuck open or flopping freely due to disconnection from actuator arm.
Mikester is offline   Reply With Quote
Old 03-24-2015, 09:53 AM   #3
Dboyizmlg
Dboyizmlg's Avatar
Dboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-known
^^ that right there
Dboyizmlg is offline   Reply With Quote
Old 03-25-2015, 08:59 AM   #4
lovethatpssh
Thank you.... And Not to sound stupid but whts the best way to fix
Old 03-25-2015, 11:28 AM   #5
Mikester
Mikester's Avatar
Connect the actuator back to the wastegate. There is a little c-clip that holds in on.
Old 03-27-2015, 12:43 PM   #6
lovethatpssh
I've looked At mine I don't see and actuator rob or anything sorry if I sound like I dk wht Im talking about I'm lost tho
Old 03-27-2015, 12:49 PM   #7
lovethatpssh
Here's a picture of it
Old 03-27-2015, 12:51 PM   #8
lovethatpssh
Here's a pic
Old 03-27-2015, 10:40 PM   #9
Mikester
Mikester's Avatar
Kinda hard to tell from your pic- Looks like an external wastegate (no rod/flapper door on those)...? Check that your vacuum lines etc going to it are properly connected and that there isn't any leaks in the connections/flanges/gaskets. I've never run an external wastegate; so other than the basics, I have no other wisdom to offer. I know the theory of operation is pretty much the same; meaning that something is either not connected, stuck in the open position or otherwise malfunctioning- The reason you aren't building boost is that the wastegate is most likely allowing all of the exhaust flow to bypass the turbine. Sorry dude.
Mike
Old 03-28-2015, 09:11 AM   #10
cotbu
cotbu's Avatar
That looks like the worst place to put an external gate. If it every worked you'd have to worry about, the divided flange, and having shitty gaskets.
I wanna see what the exhaust side of the turbo looks like, now. Maybe I'm wrong and this is the best place for an external gate.
Sent from my Highly Tuned Note 4.5!!!
Old 03-30-2015, 02:44 PM   #11
lovethatpssh
Here's another
Old 04-01-2015, 09:47 PM   #12
Yellow4g63
Yellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of light
Send a message via AIM to Yellow4g63
Stock RB turbo?
95 240sx RB20 415whp
91 Nx2000 VVL yo
Yellow4g63 is offline   Reply With Quote
Old 04-02-2015, 12:21 AM   #13
Sileighty_85
Sileighty_85's Avatar
Might have a leak somewhere, Look at your fire wall, the plastic wire loom cover is melting
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 04-02-2015, 10:08 AM   #14
seagrasser
seagrasser is an unknown quantity at this point
We need more basic information.
What turbo are you running (stock or aftermarket)
When you say exhaust "broke loose", how did that happen and what parts broke loose. What was welded, be specific.
Looks like an aftermarket wastegate and exhaust setup, please describe it or take better pictures.
Sounds like you are not building pressure, so that means either a leak or the wastegate is stuck open. There are any number of reasons for this, especially if the exhaust suffered a catastrophic failure at or near the turbo flange.
S14 RB25
seagrasser is offline   Reply With Quote
Old 04-07-2015, 02:47 PM   #15
lovethatpssh
I fixed it it was actually just the boost gauge wasn't reading the hose had a crack replaced and everything's fine... But just in case. 57 trim Garrett turbo hks exhaust. And it broke loss from the turbo.
