Old 08-11-2013, 10:41 PM   #1
pdayz93
pdayz93's Avatar
pdayz93 is an unknown quantity at this point
s13 KA transmission noise
My car just recently started making a strange noise on 08/09/13, i suspect that it is coming from the transmission. It almost sounds like a bad/low fluid power steering pump but i ruled that out by removing the belt for it and noise was still there. noise is there with the clutch engaged and disengaged, but i can hear it more with the clutch disengaged(pedal all the way down), and also the sharp sounding noise heard more towards the end of the video started at the same time also.
240sx transmission noise (sound clip) - YouTube
half way thru the video i disengage the clutch and reengage it.
couldn't embed video so theres the link to it, thanks in advance.
pdayz93 is offline   Reply With Quote
Old 08-14-2013, 10:28 PM   #2
S-Nation S13
S-Nation S13's Avatar
Trader Rating: (92)
Feedback Score: 92 reviews
Hm..would like to know as well mine makes a grinding noise when my clutch pedal it half engaged
Sent from my iPad using Tapatalk
S-Nation S13 is offline   Reply With Quote
Old 08-16-2013, 04:30 PM   #3
zerodameaon
zerodameaon's Avatar
Throw out bearing or something in the motor. If it was inside the trans it should not happen when you engage the clutch.
Need to adjust your idle?
#/f/s-chassis/395413...-pictures.html
