R230 Diff Swap in S14 Subframe
Hey Im in need of help, I fabricated my S14 Subframe to fit the Z32 TT Diff R230, have someone done this in the past? If so what OEM axles were used? Kind of confused if I must use two Z32 TT short axles or the Z32/Q45 combo axles?
Thanks for the help!! Last edited by gap450r; 08-14-2019 at 08:42 PM.. |
R230 requires a Q45 axle and a Z32 axle. I do not know the correct orientation though.
My SR20VET |
![]() Join Date: May 2003
I'm running a Z33 diff in my S14 with the upgraded Z32/Q45 Axle combo with no problems. Z33 diff are physically bigger than a typical R200 so I would imagine its close to a R230.
842whp KA-T "Anyone can make power but how long can you make it last?" |
