Sr20det Short Block/no crank
I have an S13 black top Sr20det short block for sale. Still has the oil and water pump. The cylinder walls are clean and the pistons do not have any detenation on them. Good block if you want to put in another crank or if you want to build it.
Price: 100 Located in SGV Pics: Sr20det shortblock 1 picture by Nismoknights - Photobucket Last edited by mayco_86; 12-07-2009 at 10:29 PM.. |
The motor had about 50,000 kilometers and was only driven like 3,000 miles here in the U.S. Rods are perfectly fine. It doesnt have the bearing anymore because when they took the crank they threw them away. But I will take some pics and post them up in a few hours. Let me know if your still interested.
Bump. I have decided to leave the crank with the block. But it does have a spun bearing. It is a great deal now because all u need is some machining on the crank and some new bearing and you have a good bottom end again. Let me know guys.
