Old 02-08-2016, 03:45 PM   #121
NWI1405
NWI1405's Avatar
NWI1405 is an unknown quantity at this point
8into1 is the way to go! A few of my buddy's built 8into1 exhaust on their 1400 truck that runs a 418ci LS based motor and it sounds awesome.
https://m.youtube.com/watch?v=w3dEbOC3G_M
NWI1405 is offline   Reply With Quote
Old 02-08-2016, 04:00 PM   #122
Corbic
Corbic's Avatar
My ears. That sounded like an angle grinder....
Old 02-09-2016, 08:01 AM   #123
NWI1405
NWI1405's Avatar
Haha yes it does have that tone a bit.
Old 02-15-2016, 08:48 PM   #124
offthewall
offthewall's Avatar
offthewall is making a name for him/her selfoffthewall is making a name for him/her selfoffthewall is making a name for him/her self
Blehh pic - but the ignition coils are going there (fire wall). No REAL reason the mount/move them there. Something that came to mind and thoughts it'll be neat!
Whalen's Speed R&D - IG - @MachinegunSquad - www.whalentuned.com
offthewall is offline   Reply With Quote
Old 02-15-2016, 09:55 PM   #125
StyleUp
StyleUp is an unknown quantity at this point
Looks cool man! Most people just move the ignition coils to sit on top of the valve cover.
Owner of Style Up www.styleupvisualexcite.com
StyleUp is offline   Reply With Quote
Old 02-15-2016, 10:15 PM   #126
Corbic
Corbic's Avatar
Whalen's LM7 S13 Coupe - WSRD
That's where they are on a stock engine.
The OHV design means you can't put the spark plug dead center, so the plugs are on the side. This also means you can't put coil-on plug. So GM did coil-near-plug.
The further away the plugs, the less efficient the spark.
Old 02-23-2016, 09:11 PM   #127
offthewall
offthewall's Avatar
Did some work to the never ending project. Tackled the fuel today and got it 99% finished. Got some line securing underneath to do and install another fuel filter mount bracket.
* Random underneath shot *
Old 02-26-2016, 07:23 PM   #128
theboy
theboy is an unknown quantity at this point
How much lower than your frame rails does your trans sit? I'm doing basically the same swap but with ex ASA LS motor instead.
Props man. The dingo ate your baby.
theboy is offline   Reply With Quote
Old 03-11-2016, 08:37 AM   #129
offthewall
offthewall's Avatar
I can check and get a accurate measurement.
Old 03-11-2016, 11:56 AM   #130
offthewall
offthewall's Avatar
Couple weeks ago I finished the making of the spark plug wires. MSD offered a pretty nice DIY kit. Got the job done nicely.
Got a nice call from Stainless Headers and ending up placing my header material order! Very excited to get the tubing in and start fabricating!
Next, i'll RE doing where the coolant reservoir and oil filter housing is to make room for the header (5th time doing this lol). In the mix of all this, im getting my lead harness from MegaSquirt and placing my wiring order too. Excited Excited. I hope i'll make it to racing event Gingerman (in South Haven, MI) for the even in July.
If anyone was curious lol, a RPF1 18x9.5 +15 clears a Evo 8 Brembo w/o a spacer. As the Cosmis XT006r's, 18x9.5 +10. I have to run a 25MM spacer.
Old 03-11-2016, 01:54 PM   #131
laextreme5
laextreme5's Avatar
laextreme5 is an unknown quantity at this point
Hmm, thats good to know on the msd diy kit. Do you know of any drawbacks to the spark plug wires bring that long in length, do all the wires have to be the exact same length?
My S13 Build
#/f/showthread.php?p=6005967#post6005967
laextreme5 is offline   Reply With Quote
Old 03-11-2016, 02:06 PM   #132
offthewall
offthewall's Avatar
Meh, I don't think plug wire length will play any negative affect on the performance on this engine.
Googled a 2500HP 676CI engine, his spark plug wires are rather long and makes some serious jam. And regardless, I MIGHT brake 400HP on my set up... on a good day.
Old 03-11-2016, 02:07 PM   #133
laextreme5
laextreme5's Avatar
Good to know. What diy kit did you order?
My S13 Build
Old 03-11-2016, 06:32 PM   #134
Heywood Jablomie
Heywood Jablomie is an unknown quantity at this point
You're shooting for 400hp with this? Jesus why not just stay NA if that's all you're looking for?
Heywood Jablomie is offline   Reply With Quote
Old 03-11-2016, 07:09 PM   #135
offthewall
offthewall's Avatar
My bad, I decided to stay NA for now. Really want to learn to drive this before I double to HP when it's turbochargered. We'll see though.
Old 03-15-2016, 04:33 PM   #136
offthewall
offthewall's Avatar
YESS!
Old 03-15-2016, 04:57 PM   #137
TheRealSy90
TheRealSy90's Avatar
8 into 1 is amazing. Such sound. Are you going to put it in the same area as Ross Petty's S15? Honestly I can't see an 8-1 setup fitting anywhere else haha. Might as well copy his setup, or at least use the pictures of it for reference.
Such a good signature.
Old 03-15-2016, 08:56 PM   #138
scottie
scottie's Avatar
Damnit you got your piping before me! We will have to compare designs once complete. Are you using any modeling software or the kit to configure the runners? I've looked into the ice engine works kit but the cost has me on the fence.
Old 03-15-2016, 09:35 PM   #139
Green Arrow
Green Arrow Green Arrow Green Arrow Green Arrow Green Arrow Green Arrow Green Arrow Green Arrow Green Arrow Green Arrow Green Arrow
Not familiar with Pettys set up, where TF will the collector fit?
Green Arrow is offline   Reply With Quote
Old 03-16-2016, 07:32 AM   #140
offthewall
offthewall's Avatar
No modeling software. Luckily I have some extra pair of hands that are a little more experienced than me to help with this.
Old 03-16-2016, 08:07 AM   #141
TheRealSy90
Here's the only pics I've ever found that show you his 8-1 setup under the car. Dan at Parts Shop Max custom made this setup for Ross. Looks like his collector is next to the transmission just after the crossmember. I don't remember if his S15 was right had driver or not, but it looks like the floor pan has been modified to fit the exhaust a bit.
Old 03-16-2016, 08:31 AM   #142
offthewall
offthewall's Avatar
Yeah, thats all I've found. BUT, I'm not routing mine down underneath like he did.
Sent from my SM-G928P using Tapatalk
Old 03-17-2016, 08:52 AM   #143
offthewall
offthewall's Avatar
Shop Pup!
It's begun!
Old 03-17-2016, 09:18 AM   #144
laextreme5
laextreme5's Avatar
OOhh i cant wait, this gone be gud. Also the s15 shots, it looks like they just placed the collector where the stock cat goes in the hump that is already there. Although in that placement the primaries must be quite long, must make for a very low end torquey power band.
Offthewall. Have you measured for primary lengths and have a length goal in mind? also are you making them all equal length?
My S13 Build
Old 03-17-2016, 11:50 AM   #145
offthewall
offthewall's Avatar
Yes, I'm for sure keeping that in mind. It's already getting pretty crazy and i'm not even close to half way done. This weekend it SHOULD be dang near complete.
Old 03-17-2016, 11:58 AM   #146
laextreme5
laextreme5's Avatar
Good, hate to see you put in all that hard work then the length is way off from your desired powerband. Cant wait to hear this thing. Its going to fire up WAY before mine haha
My S13 Build
Old 03-18-2016, 07:25 PM   #147
TheRealSy90
But don't FD guys WANT a torquey powerband. Thus the LS craze...
Old 03-18-2016, 10:12 PM   #148
laextreme5
laextreme5's Avatar
To an extent yeah, but you dont want peak tq way down low like say 3-3500 rpm. the length of the primaries on the s15 mentioned were extremely long. Longer the primaires the lower the peak tq will be. Granted thats a general statement ignoring other variables such as primary diamter, engine size, max rpm etc. Regardless primary length is the biggest factor in tq production in a certain area in the powerband.
My S13 Build
Old 03-20-2016, 02:48 PM   #149
offthewall
offthewall's Avatar
Whatta mess!
Old 03-21-2016, 12:11 PM   #150
rgnhd
rgnhd is an unknown quantity at this point
I hope you are running a rear mounted Rad...
rgnhd is offline   Reply With Quote
