Old 06-13-2012, 04:02 PM   #1
Sam091990
Sam091990 is an unknown quantity at this point
2JZ Swap Brackets/Mounts
So I've been looking around for the brackets to do the swap and just had two questions that I couldn't find an answer to.
1. The transmission bracket that is included, will it work with the W58 transmission or only the R154?
2. Since they are only brackets, can you use any off the shelf engine/transmission mounts?
Sam091990 is offline   Reply With Quote
Old 06-13-2012, 04:23 PM   #2
KendallH
KendallH is an unknown quantity at this point
HMS/Hybrid Motorsports make a good set of mounts that utilize S-chassis motor mounts, stock or aftermarket.
KendallH is offline   Reply With Quote
Old 06-13-2012, 04:38 PM   #3
jdm2191
jdm2191's Avatar
Trader Rating: (79)
jdm2191 is an unknown quantity at this point
Feedback Score: 79 reviews
I dont know exactly on what brand your talking about? But with most swap kits, not all u need to tell em what tranny your running. An with motor mounts again depending on brand most the time you can use stock 1JZ/2JZ mounts & sometime even KA/SR Mounts but it all depends on brand
as your questions in this thread it should help more
#/f/engine-tech/3841...is-thread.html
My Build: The "Coupe De Ville" 1JZ Build!!
jdm2191 is offline   Reply With Quote
Old 06-13-2012, 05:02 PM   #4
7jpat
7jpat is an unknown quantity at this point
: Tech2 Motorsports : Home :
their pricey but the best ive seen call them they should be able to answer anything for u
7jpat is offline   Reply With Quote
Old 06-13-2012, 05:05 PM   #5
Sam091990
Tech2 includes mounts but if I'd like to replace them they don't specify what's compatible with their brackets. I would assume the 2JZ factory mounts will fit their brackets, but I can't find a 100% answer.
They also don't specify if the transmission bracket will work for a W58. It says to add $150 for a V160, but no other information.
As for the eBay ones, they specify the transmission bracket is for a R154 but I'm wondering if it would work for a W58 as well. I have a W58 sitting in the garage and the mount for it looks like the mount for an R154.
They also mention that the engine brackets will work with stock or aftermarket mounts, so one would assume they are referring to the 2JZ mounts. I doubt anyone will have much information about the eBay set, but thought I'd ask anyway. I've already contacted the seller as well.
240SX S13 S14 SWAP ENGINE MOTOR MOUNTS BRACKETS 1JZ 2JZ | eBay
Old 06-13-2012, 05:18 PM   #6
thefro526
thefro526's Avatar
I have Zerolift mounts which are basically improved ruckus racing mounts. The ebay mounts are a rip of the ZL/RR design - but made in China. I honestly would say to buy the ZL mounts if you can make the money work.
As far as isolators (mounts) I have a pair of Driftfreaq engine isolators and a driftmotion poly trans mount. The engine sits well, although it's the wrong size in all of the wrong places. Oh well...
TLDR; Ebay mounts suck, tech2 stuff is mega expensive, JZ's are rad.
thefro526 is offline   Reply With Quote
Old 06-13-2012, 08:52 PM   #7
sil80d
sil80d is an unknown quantity at this point
I have get nutz brackets on two cars. Forrest mount kits are the best. Hands down
sil80d is offline   Reply With Quote
Old 06-14-2012, 08:38 AM   #8
2muchboost
Trader Rating: (33)
Feedback Score: 33 reviews
Sent a pm....
The ebay kit is designed to use a 240sx motor mount....either stock, nismo, avid, etc.
The trans mount is designed for the R154 but could be modified to accept the W58 by simply drilling out the new trans mount bolt pattern. Its been done before and can be done that simply....mock up, mark bolt location, drill holes, drop right in.
Old 06-14-2012, 12:39 PM   #9
Sam091990
The eBay mounts are a bit sketchy, but I've heard people run them without any problems and since I plan on running the engine stock for the time being, they might not be so bad.
Tech2 is way too expensive, and I was actually interested in ZL/RR but after a ton of searching I can't find anywhere to buy them.
Any links where I can find these?
Originally Posted by Steven17 View Post
I like this.
Originally Posted by 2muchboost View Post
Sent a pm....
Replied.
Old 06-14-2012, 04:18 PM   #10
2muchboost
Trader Rating: (33)
Not sure why people think Ebay mounts suck when 99% of people that use them have had no issues or very small issues which can be fixed. I dropped the engine in with the brackets and had no issues. Only reason motor came back out is because I am overhauling it with the OEM gasket kit which to me is easier done with the motor out of the car.
Anyone that has had issues with ebay 2jz mounts speak from experience?
So far these people have posted that ebay mounts worked for their setup:
1j240sx (and his friend)
VitalyS
S14Pit
Old 06-14-2012, 04:20 PM   #11
Flicktitty
Flicktitty's Avatar
I have the tech 2 stuff going on 4+ years with it. No issues other then it sits somewhat crooked.
Old 06-14-2012, 06:41 PM   #12
Sam091990
I wouldn't mind getting the Tech2 kit but it's just WAY too much money. Maybe if I planned on doing a 600HP+ build I'd buy it, other than that there really is no point.
