Old 02-24-2002, 08:31 PM   #1
twofourtysx
twofourtysx is an unknown quantity at this point
Hi again.  My car's clutch gets stuck occasionally and i have to use my feet to pop it back up.  Has this happened to anyone else?  It doesnt happen all the time, but once in a while it gets stuck.  Also, my clutch squeaks which sounds horrible.  any advice? thanks.
twofourtysx is offline   Reply With Quote
Old 02-24-2002, 08:50 PM   #2
S13Grl
Married to the Mob
S13Grl's Avatar
S13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to all
#Moderation Mode
<a href="#/forums/cgi-bin/topic.cgi?forum=2&topic=2142" target="_self">Moved here</a>
S13Grl is offline   Reply With Quote
Old 02-24-2002, 08:53 PM   #3
camppain
Will never get banned...
camppain's Avatar
camppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enough
Send a message via AIM to camppain Send a message via MSN to camppain Send a message via Yahoo to camppain
gets stuck or the pedal doesnt return? if thats the case sounds like you have either a leak in your lines or air in your sys. bleed your clutch first and see if that disappears.
as for the squeaking see if your pedal bushing is worn if so replace it its like 2 bucks from nissan
camppain is offline   Reply With Quote
Old 02-24-2002, 09:02 PM   #4
Gismo R
Gismo R is an unknown quantity at this point
I have the same problem. I agree the squeaking is terrible. I sprayed some WD40 above the pedel, where the spring is, and the noise went away. It also got rid of the sticking. But that only lasts for so long. BTW how do you bleed your clutch, And what does it do??
Gismo R is offline   Reply With Quote
Old 02-24-2002, 09:12 PM   #5
camppain
camppain's Avatar
to bleed your clutch
1.raise your vehicle
2.have someone pump the clutch pedal a few times
3.use a 10 mm line wrench to loosen the dampner (this is the part just before the slave cylinder) fluid comes out re tighten
repeat step 2 then repeat step 3.
next part again repeat step 2
4. using 10 mm line wrench loosin bleeder screw on slave cylinder (this is mounted on the trans case itself) let fluid drain and retighten
repeat steps 2 and 4 till satisfied
note: keep an eye on your master cylinders fluid level it goes by fast. also remeber the clutch pedal will not return automatically it is not under vacuum like a brake pedal so the person pumping the clutch would need to pull it up
hope this helps and remeber the 240s system is one of the most annoying systems to bleed ask any nissan tech
Old 02-24-2002, 09:17 PM   #6
camppain
camppain's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from Gismo R on 9<img src="#/f/iB_html/non-cgi/emoticons/wow.gif" border="0" valign="absmiddle" alt=':0'>2 pm on Feb. 24, 2002
</td></tr></table><span id='postcolor'>
bleeding your clutch takes the air out of your pedal and the instructions above are how to do it
Old 02-24-2002, 09:38 PM   #7
jmharr
jmharr is an unknown quantity at this point
I had the same problem, ended up needing a new slave cylinder, pretty cheap job.
jmharr is offline   Reply With Quote
Old 02-24-2002, 09:39 PM   #8
jmharr
(Edited by jmharr at 9:40 pm on Feb. 24, 2002)
Old 02-24-2002, 09:40 PM   #9
Devilish240
Devilish240 is an unknown quantity at this point
Hi, it did the same thing to me once (it was pouring outside, so much i couldnt see &nbsp;nothing in front of me.. so i pulled over and when the weather was better, i tried to go in first gear and it wouldn't plus my pedal was stuck ?!?!?!?!) So i did bleed the clutch afterwise.. and it did it again once... during rain (plus horn beeped by itself ?!?!? and died on me then ) Anyways, my solution is to stay in on rainy days... lol
Devilish240 is offline   Reply With Quote
Old 02-24-2002, 10:43 PM   #10
twofourtysx
yea i noticed that on rainy days my clutch began to squeak. &nbsp;its #### embarrassing when you have people in the car. &nbsp;
Old 02-25-2002, 09:29 AM   #11
RoNx777
RoNx777 is an unknown quantity at this point
Its funny cuz that happened to me for the first time yesterday ... but once I brought it back up with may foot that was the end of it...didnt happed again.
Hopefully itz only a one time thing.
RoNx777 is offline   Reply With Quote
