For Sale Items Post items for sale here. ABSOLUTELY NO COMMERCIAL SALES. |
The Architect.
![]() Join Date: May 2006
Trader Rating: (392)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 392 reviews
![]() SHIPPING: At buyers expense
CONTACT INFORMATION - [email protected] or via PM. LOCATION: Los Angeles, CA PAYMENT OPTIONS: Cash, Paypal ![]() Current List S13 $400 - S13 SR20 HPI Turbo Manifold and Elbow set $20 - S13 Hatch trunk glass trim (sits on the inside) $20 - S13 Hatch trunk lid trim $30 - S13 Hatch trunk interior panel $30 - S13 Power steering reservoir $40 - S13 KA24DE Agency Power Radiator Hose set $75 - S13 SR20DET Aluminum Radiator $40 - S13 KA24DE Charcoal Canister $40 - S13 KA24DE Exhaust Emissions set $40 - S13 KA24DE Ignition coil $20 - S13 Driver's side seat trim $20 - S13 Passenger side seat trim $125 - S13 Yanack Reinforced Urethane Motor Mounts $350 - S13 180sx Origin Racingline Carbon Fiber Rear Bumper under panel $350 - S13 180sx Origin Racingline Carbon Fiber Sideskirt under panels $350 - S13 180sx Origin Racingline Carbon Fiber Front bumper under panel $500 - S13 PBM PRO Front Lower Control Arm set (new, only test fitted) $500 - S13 PBM PRO Rear Lower Control Arm set (new, only test fitted) $20 - S13 Radio brackets $100 - S13 ATS-BM Toe Arms $700 - S13 180sx Origin Racingline rear bumper with under panel set (new, only test fitted) $310 - S13 180sx Type 3 Trunk Wing (new, only test fitted) $300 - S13 Apexi GT Spec Exhaust (dented underside) $20 - S13 Dome light $10 - S13 Rear shock tower covers $10 - S13 Hood prop (three available) $40 - S13 Passenger door handle assembly $10 - S13 Dampening Adjustment knob for S13 Megan Coilovers $20 - S13 Radial bearing mount for S13 Megan Coilovers $25 - S13 Coilover spring for S13 Megan Coilovers (front) $15 - S13 AC Vent 3 Gauge Holder 52mm $50 - S13 KA24DE MAF $75 - S13 KA24DE OEM Intake Assembly $10 - S13 AC vent dual gauge holder $30 - 180sx Position Light (right side) brand new $10 - S13 Driver's side door sill $20 - S13 Cusco license plate bracket S14 $100 - S14 SR20DET Koyo Aluminum Radiator $60 - S14 SR20DET Koyo OEM Replacement Radiator $50 - S14 GK Tech Solid steering rack bushings $200 - S14 Swift Front Swaybar $10 - S14 Dust boot with bump stop for S14 Megan Coilovers $10 - S14 Dampening adjustment knob for S14 Megan Coilovers $10 - S14 Coilover spring perch/locking collars for S14 Megan Coilovers (priced individually) $75 - S14 Camber plates for S14 Megan Coilovers $75 - S14 Lower mounts for S14 Megan Coilovers $20 - S14 Transmission tunnel brace (two available) $40 - S14 Power Steering lines $50 - S14 Rear seat belt set $20 - S14 Sideview mirror switch $40 - S14 Automatic Shifter assembly (removed from '97 240sx) $20 - S14 Driver's side window / glass (two available) $30 - S14 Passenger door handle $10 - S14 passenger side kouki bulb holder Brakes Wheels $1000 - SSR GT2 19x8.5 +42 | 19x10 +25 | 5x120 BMW Specs Electronics $150 - Braille B2317 Lightweight Battery $45 - Autometer Fuel Gauge (new) $100 - HKS PFC $40 - Flex-a-lite Fan Controller Engine $500 - HKS Type R Oil Cooler kit for S13 SR20DET $225 - Garrett M24 Turbo Charger AR. 48 T25 Flange $50 - Tomei SR20DET Rocker Arm Stoppers (brand new) $50 - RB25 OEM Turbo Elbow $200 - Syko RB25 to S13 Motor and Trans mount kit $30 - ISIS RB25 to S13 Radiator Hose kit $50 - 90MM Universal Throttle Body $15 - KA/SR MAF Intake Filter adapter $10 - ID Coolant Overflow tank Drivetrain $125 - S15 HLSD Half Shafts 38220-4P061 (two available) Misc $75 - Takata rep harness $5 - NRG Horn button $15 - Epman Tow Straps pair $25 - JDM Crystal Steering wheel spinner knob (new) S13 Items $400 - S13 SR20 HPI Turbo Manifold and Elbow set $20 - S13 Hatch trunk glass trim (sits on the inside) $20 - S13 Hatch trunk lid trim $30 - S13 Hatch trunk interior panel $30 - S13 Power steering reservoir $40 - S13 KA24DE Agency Power Radiator Hose set $75 - S13 SR20DET Aluminum Radiator $40 - S13 KA24DE Charcoal Canister $40 - S13 KA24DE Exhaust Emissions set $40 - S13 KA24DE Ignition coil $20 - S13 Driver's side seat trim $20 - S13 Passenger side seat trim $125 - S13 Yanack Reinforced Urethane Motor Mounts $350 - S13 180sx Origin Racingline Carbon Fiber Rear Bumper under panel $350 - S13 180sx Origin Racingline Carbon Fiber Sideskirt under panels $350 - S13 180sx Origin Racingline Carbon Fiber Front bumper under panel $500 - S13 PBM PRO Front Lower Control Arm set (new, only test fitted) $500 - S13 PBM PRO Rear Lower Control Arm set (new, only test fitted) $20 - S13 Radio brackets $100 - S13 ATS-BM Toe Arms $700 - S13 180sx Origin Racingline rear bumper with under panel set (new, only test fitted) $310 - S13 180sx Type 3 Trunk Wing (new, only test fitted) $300 - S13 Apexi GT Spec Exhaust (dented underside) $20 - Dome light $10 - Rear shock tower covers $10 - Hood prop (three available) $40 - Passenger door handle assembly $10 - Dampening Adjustment knob for S13 Megan Coilovers $20 - Radial bearing mount for S13 Megan Coilovers $25 - Coilover spring for S13 Megan Coilovers (front) $15 - AC Vent 3 Gauge Holder 52mm $50 - S13 KA24DE MAF $75 - S13 KA24DE OEM Intake Assembly $50 - S13 Rear Knuckle set $10 - S13 AC vent dual gauge holder $30 - 180sx Position Light (right side) brand new $10 - S13 Driver's side door sill $20 - S13 Cusco license plate bracket S14 $10 - Dust boot with bump stop for S14 Megan Coilovers $10 - Dampening adjustment knob for S14 Megan Coilovers $10 - Coilover spring perch/locking collars for S14 Megan Coilovers (priced individually) $75 - Camber plates for S14 Megan Coilovers $75 - Lower mounts for S14 Megan Coilovers $20 - S14 Transmission tunnel brace (two available) |
The Architect.
$60 - S14 SR20DET Koyo OEM Replacement Radiator $50 - S14 GK Tech Solid steering rack bushings $200 - S14 Swift Front Swaybar $40 - S14 Power Steering lines $50 - S14 Rear seat belt set $20 - S14 Sideview mirror switch $40 - S14 Automatic Shifter assembly (removed from '97 240sx) $20 - S14 Driver's side window / glass (two available) $30 - S14 Passenger door handle $10 - S14 passenger side kouki bulb holder Brakes Wheels $1000 - SSR GT2 19x8.5 +42 | 19x10 +25 | 5x120 BMW Specs Electronics $150 - Braille B2317 Lightweight Battery $45 - Autometer Fuel Gauge (new) $100 - HKS PFC DESCRIPTION: I received this with a car I just bought and I don't have any use for it so someone else here can put it to use. Here's the product description from HKS. It's for 1989-1994 S13 SR20DET's. The HKS PFC F-CON is a plug-in fuel management system designed to supplement and refine the OEM fuel curve to maintain a proper air/fuel mixture when increasing boost pressure in turbocharged applications. The PFC F-CON optimizes the factory injector pulse width signal by recalibrating information obtained by both the PFC F-CON absolute pressure sensor and the OEM engine control unit (ECU). Each unit is application specific and includes a preprogrammed ROM for a particular performance stage. —- A Fuel Cut Defencer (FCD) is also included in certain PFC F-CON kits to override the factory fuel cutoff. The PFC F-CON offers easy integration via a plug-in vehicle specific wiring harness and a compact pressure sensor. If additional adjustment of the PFC F-CON is needed, fine-tuning can be performed via the plug-in HKS Graphic Control Computer (GCC). $40 - Flex-a-lite Fan Controller Engine $500 - HKS Type R Oil Cooler kit for S13 SR20DET $225 - Garrett M24 Turbo Charger AR. 48 T25 Flange $50 - Tomei SR20DET Rocker Arm Stoppers (brand new) $50 - RB25 OEM Turbo Elbow $200 - Syko RB25 to S13 Motor and Trans mount kit $30 - ISIS RB25 to S13 Radiator Hose kit $50 - 90MM Universal Throttle Body $15 - KA/SR MAF Intake Filter adapter $10 - ID Coolant Overflow tank Drivetrain $125 - S15 HLSD Half Shafts 38220-4P061 (two available) |
The Architect.
Updating posts.
The Architect.
JDM S14 DEPO Clear Fender marker lights
- Good shape overall. Can be made to fit just about any other car. Price - $30 |
#11 | ||
The Architect.
Not looking to ship the carpet. Sorry about that.
Sold. Sorry about that. Not looking to ship the pignose lip. |
The Architect.
Holding onto it for now. I'll let you know if I decide to sell that unit.
#30 |
The Architect.
Original post updated.
