Old 09-26-2012, 10:58 PM   #1
boris13
boris13 is an unknown quantity at this point
s13 SR20DET No Start Code 11
Hey i need some help with my sr20det i just got the car running good and all of the sudden last night i pulled up into my drive way and was letting the car idle before turning it off and it died on me out of no where.
I went to check to see if my fuel pump was priming took it out an checked but its not also went to swap out the Fuel pump relays (EGI) both green and still no luck after trying that i checked the ecu and it was throwing a code witch is code 11 CAS i believe already did some research but found nothing could the cas be off causing the car not to start.? it cranks but it wont fire up.
also could that code stop the fuel pump from priming.? i find it really weird that it wont prime any more already did the fuel pump upgrade to the 255 Walboro and its brand new Im really stumped any insite or help would be very appreciated.
PS its a s13 sr20det redtop
people only hate on my 240sx because its a 1990 and i murder their 2012's
boris13 is offline   Reply With Quote
Old 09-27-2012, 08:09 AM   #2
boris13
any one.?????
Old 09-27-2012, 09:13 AM   #3
91ka24
91ka24's Avatar
91ka24 is an unknown quantity at this point
Did u check fuel pump fuse?
91ka24 is offline   Reply With Quote
Old 09-27-2012, 09:23 AM   #4
murffy
murffy's Avatar
Trader Rating: (44)
murffy is an unknown quantity at this point
Feedback Score: 44 reviews
+1 on checking the fuel pump fuse..on an s13 it's in the engine bay inside the black fuse box..also check the grounds..there's on right behind that same
Box and there is one in the trunk/hatch I believe..check that make sure nothining inside your trunk/hatch might have cut your harness..as for code 11 your cas could actually stop your car from starting because it controls timing and injector pulse..so make sure it's on correctly and plugged in..another thing is the small ground behind the head that goes connected to your firewall make sure that small shoelace ground(or wire if you changed it) is hooked up trust me it matters. What throws me off is that your car was running before..did you rebuild the motor? If so
You might have set the timing chain on wrong..let me know and I'll try an help you out as much as I can
murffy is offline   Reply With Quote
Old 09-27-2012, 11:07 AM   #5
boris13
Thanks for the help guys I checked the egi and egi relays swapped them out with two different ones and still no luck the fuel pump fuse is good too I haven't rebuilt the motor and what's weird was that I went to McDonald's to get food came back and I always wait 3 min before I shut the car off to let the turbo cool off i didn't open her up or anything but still I just replaced the turbo but as soon as I was going to turn her off she just died after replacing the relays and no luck with that I checked the ecu for codes and it only gave me a code 11 I have taken it out once before to set it right but I'll check those wires you told me about I'm at work but I'll still reply to this post through my phone but again thanks for the help I really appriciate any and all the help I can get
Old 09-27-2012, 11:08 AM   #6
boris13
Just one more thing would that code cause my fuel pump not to prime.??
Old 09-27-2012, 12:33 PM   #7
murffy
murffy's Avatar
Trader Rating: (44)
Alright keep us updated..no that code doesn't effect the fuel pump
Old 09-27-2012, 06:11 PM   #8
boris13
ok i changed the relays n still no luck bought them brand new not getting any power from the blk n pink wire (fuelpump) from the back of the ecu already tryed a diffrent ecu as well
Old 09-27-2012, 06:45 PM   #9
cotbu
cotbu's Avatar
Last time! The black with pink stripe wire, is the ground trigger signal wire for the fuel pump relay. It is controlled by the ecu. Open your ecu locate pin 104 with an ecu pin out. Follow the traces look for burnt or broken traces (post picture if you don't know what you're looking at!) If you tested the wiring from the relay to the pump? I'm sure it's either: black/Pink wire broken (check continuity), Broken / fried trace or Bad ecu!
Old 09-27-2012, 07:17 PM   #10
boris13
thanks for the info i checked with a multimeter on the black box by the throttle body and everything checked out with sticking the prongs in where the relay goes im getting power there i took the multimeter to the blk/pnk wire pin 1047 on the ecu and checked for a voltage reading behind the ecu and got no reading what so ever from the back of the ecu to the blk/pink wire what voltage is it supposed to be getting.?
Old 09-27-2012, 07:46 PM   #11
boris13
or any write ups for a fuel pump direct wire up to turn on the fuel pump with a switch or something.?
Old 09-27-2012, 08:03 PM   #12
cotbu
cotbu's Avatar
Make a jumper wire, 3-4 inches long. looking into the relay socket, top row from passengers side 1. 2 bottom row 3. 4. . jump pins 2 and 3 or 4 and 3. The fuel pump should turn on and off with the key. No external switch required.
Old 09-27-2012, 08:50 PM   #13
boris13
k thanks for the advice well i found out that my fuel pump is not fried since i did that and it primed i also fixed the cas and realigned the dots up so thats taken care of now i still cant find a solution as to why the fuel pump wont prime by its self the ecu is throwing code 55 and i swapped ecus already to see if my ecu was fryed but its not
now i wanna know if there would be any way to bypass the relay and wire direct voltage to the fuel pump and not have it run on the main harness just two simple cables negative and positive and have a fuse and a switch attached to it so i can turn the fuel pump on and off when ever i want to start the car ive looked but havent found anything anywhere a link to how its done with some pictures is all this noob can ask for :P but again thanks for all the help this forum has helped me so much i cant thank you guys enough
ps sorry about the novels i have bin writing i try to keep it short and simple
Old 09-28-2012, 09:52 PM   #14
boris13
ok guys i went and bought a relay and also found out how to hook it up i acutally followed the write up that cotbu made here is the link i followed the diagram prefectly but my fuel pump is still not priming (heres the link)
#/f/tech-talk/151881...-hot-wire.html
also jumped the egi pump relay like in the picture but still got no luck with it could it be a bad ground some where.? am i missing something.?? i spent 2 hours in the rain today trying to get everything done but it started pouring so i had to put it off till tomorrow any help would be very very appreciated.
Old 09-28-2012, 10:45 PM   #15
cotbu
cotbu's Avatar
The ecu could have a burnt trace for the fuel pump, the black and pink wire could be broken. Those are reasons why the ecu wont prime the pump. I'm confused because your saying now, the pump won't power on, after you made a jumper wire? you probably wired the relay wrong. So I would probably have you start from scratch, just to eliminate any confusion.
Old 09-28-2012, 11:37 PM   #16
boris13
ok well heres the thing now that i did that jumper wire like you showed me i put them in the correct pins like i saw in the picture and the pump would not prime with the key turned to the accessorys on
i checked the volts with the jumper cable on as well and i got 12v to the fuel pump but it still wont prime i also did the relay the wire i hooked up was from the positive battery and hooked it up to the 30a fuse then from there hooked it up to the 87 prong on the relay i hooked up the 86 prong is hooked up to the blue/pink wire on the pump witch is the negative side on the fuel pump and the 30 prong is hooked up to the blue/pink wire on the harness prong 85 is grounded but there is nothing hooked up to the positive side of the fuel pump and there is a one prong left in the middle of the relay i believe its showing as the 87q or something like thast what should be hooked up the the positive wire on the fuel pump.?
Old 09-29-2012, 12:42 AM   #17
cotbu
cotbu's Avatar
86 is the relay energize trigger, it comes from the stock wiring.
30 goes to the FP power wire, power for the fuel pump
85 is chassis grounded
87 is the only one that appears connected correctly
87a leave unconnected
Leave the fuel pumps ground wire connected normally or add a new chassis ground.
Old 09-29-2012, 05:29 PM   #18
boris13
ok so what i got now is the 87 hooked to the positive terminal on the battery
i got the 30 on the relay to the fuel pump positive side
85 is grounded to the chassi
86 to the harness from the fuel pump positive side going away from the pump i am about to post pictures
Old 09-29-2012, 07:33 PM   #19
boris13
well im getting fuel but it still wont start up it cranks over and it sounds like it wants to start but it just back fires as its cranking (crank crank crank crank pop pop pop pop) as if it wants to fire up but it doesnt. the relay did not work for shit idk if im doing it wrong
Old 09-29-2012, 07:39 PM   #20
boris13
i believe my timing is off now i know that i need to hand crank the motor to the first notch on the crank pully but how do i line up the dots with the marks on the chain do i have to take the whole chain off and put it on right.?
Old 09-29-2012, 07:40 PM   #21
boris13
How To Set Crank Angle Sensor (CAS) Timing on the SR20DET Engine
Old 09-29-2012, 07:41 PM   #22
boris13
i crank and crank and crank the pully but they never line up correctly
Old 09-29-2012, 07:43 PM   #23
cotbu
cotbu's Avatar
You shouldn't have to mess with the chain unless you previously moved it.
set the no.1 piston to tdc on compression stroke, re stab cas. the set timing via light to 15deg
remove no.1 spark plug, insert a long dowel or screw driver into the hole, watch as you move the crank marks to tdc, the screw driver will stop moving up.
That's TDC
Old 09-29-2012, 08:12 PM   #24
boris13
Ok cuz I never moved the chain inside I'll try that tomorrow any insite as to why it would do that.? Man I can't thank you enough for helping me out I was stuck here trying everything I'll post the pictures of how I set up the relay as soon as i get home for some reason I only get power to the 87 but no power to any other out put on the relay
Ps I don't wanna seem like a dumb ass asking all these questions but your the only guy helping me out with it THANKS A BUNCH.!!!
Old 09-30-2012, 05:23 AM   #25
cotbu
cotbu's Avatar
You mean the pop pop pop, after cranking? Usually timing probably, 180degs off.
I was waiting for pictures, but if you're still having issues? We might need to test a few things.
You could always donate to the forum, care of me, lol... and you'll get to go blue!
Old 09-30-2012, 06:17 PM   #26
boris13
SIR YOU ARE THE MOTHER FUCKING SHIT.!!!!!!!!!!!! seriously i really cannot thank you enough you my friend have gotten my sr20 started and running i WILL donate to this forum now to post those pictures sorry for the late reply i just got out of work and did everything you told me to do and got that bitch running
now for those pictures about the relay is probably the only thing holding me back now give me a sec
Old 09-30-2012, 06:34 PM   #27
boris13
this is what i went out and bought
this is everything hooked up wrong im assuming
close up of everything i hooked up.
this is prong 86 connected to the wire away from the FP to the harness
this is prong 30 connected to the positive wire going into the fuel pump
last one is prong 85 grounded to the chassi
prong 87 is the red positive wire thats going to the 30A fuse and from the fuse to the battery
Old 09-30-2012, 06:36 PM   #28
boris13
shit the last picture was supposed to be this one prong 85
Old 10-01-2012, 04:39 PM   #29
boris13
well i took out my multi meter and found out that pin 87Q is giving out the power for the 12v im still confused as to what is happening.
Old 10-01-2012, 07:34 PM   #30
cotbu
cotbu's Avatar
Your relay is not being energized.
Try swapping pins 85 and 86 on the relay
if still no go, try swapping 87 and 30.
if still not working pin the pins back in their original configuration.
Test the voltage at pin 86 with key on engine off. There should be battery voltage.
with battery voltage going to 86 ground 85 there should be a click, if no click replace the relay.
Careful with this test, the pump will run if still connected. and it should.
