How do i install new cd deck with the bose system ..
IM TRYING TO INSTALL AN AFTERMARKET PIONEER DECK INTO MY 300ZX. THE 300ZX HAS ALL THE STOCK WIRING PLUGS, BUT WHEN I BOUGHT THE CAR IT DIDNT COME WITH THE OEM STEREO. DOES ANYBODY HAVE ANY IDEA HOW TO WIRE UP THE DECK TO MY STOCK HARNESSES? oh btw it has bose so it makes it a little harder. and im sorry my caps lock was on so im not yelling lol
The pretty one Arn't free and the free one Arn't pretty
![]() Join Date: Jun 2003
if your caps lock is on, turn it off and retype. stop being a lazy dick if you expect to get any answers.
the bose system likely has some external amps. you'll have to bypass those and just wire up the head unit with the appropriate adapter harness from any car stereo shop or auto parts store.
![]() Join Date: Aug 2009
^^ that guy is right get the adapter harness from stereo shop then just match alike colors
LOTS OF SR20,ka24de,s13 goodies for sale check my threds |
#4 | |
Heres what you do. Go to Pepboys or Walmart and find a harness (Nissan 199x 300zx etc) that will plug into the stock audio connecter (Purples, Whites, Greens, Orange, Blues, Red, Black some with black or white stripes on them)... Using the harness provided with the head unit you purchased and the new harness you just bought from wherever, solder the connections and wrap in electrical tape or you can crimp them using connectors. Purchase an antenna adapter if you got the old school two prong piece of shit. Then your set. "it has bose so its harder" blah blah blah its all the same. The only problems I can see you running into with the Bose speakers are the extra amps you got for the tweeters.. for the rest. the Front/rear speakers should work fine. |
i forgot about that, bose speakers are often 2 ohms, overworking the new headunit (most are set up for 4 ohms). new speakers are probably a good idea too, partly to get rid of the bose shit.
well i know how to do the colored matching parts, but i just dont know how to get it work with the bose .. so pretty much is
go buy the stereo harness from whatever for my car then color match it then plug it in ?? i dont really care about the tweeter ... as matter of fact i dont use them , i just want the back and the front speaker to work .
![]() Join Date: May 2004
The Bose system uses amps at each speaker. You need a converter to lower signal strength from the head unit to the speaker. Any car audio store will have this. If you dont your volume will be to loud at low volume levels.
![]() Join Date: Jul 2010
![]() Feedback Score: 21 reviews
If theirs a frys electronics around your area. go their,buy the harness they wil offer to install it for 25bucks an you'll save yourself some headaches an what not.or best buy,audio shops usually overprice stuff
the install is easy i can install it my self... but what i dont get is what do i need to finish the job...
the harness for the aftermarket deck to the stock factury plug the converter for lower signal ? the interface for bose ????? is that all ?
#10 | |
try google, this shouldn't be hard to find.
there they're their they're all different, learn to use them and you'll look like less of an idiot. isn't that easier to comprehend? but to comment on that, audio shops generally are staffed by more competent workers than the monkeys at best buy. you get what you pay for.
![]() Join Date: Oct 2006
Trader Rating: (163)
We are going to make this real simple. You have three choices:
A) You can buy a standard wiring harness and wire it up to the aftermarket radio color for color. However, you will need to bypass all four Bose amplifiers AND replace all of the Bose speakers with aftermarket. The Bose speakers are 1-ohm and cannot be wired to the aftermarket radio. Sure it may work for a bit, but it will eventually burn up the amplifier outputs out of the radio. Good news is you can simply bypass the amplifier at each amplifier plug. Which means you won't have to run new wires like you do on some vehicles. B) You can buy a standard wiring harness and wire it up to the aftermarket radio color for color except for the speaker connections. You will not use the speaker wires out of the aftermarket headunit and instead get two sets of RCA cables and cut the ends off. You will wire these into the speaker wires on the wiring harness you bought then simply plug them into the RCA outputs on your radio. This way you are supplying a low level signal to the Bose amplifiers. However, this doesn't always work. You can get bad noise or interference depending on the preamp voltage of your radio and the quality of noise suppression it has built into it. C) You can do it the absolute right way and buy an interface designed to add a radio to an OEM Bose system. These generally run about $40 or so. This module will allow you to match the output of your radio to the input of the Bose amplifiers. I use the ROEM/NIS1. It will come with the wiring harness for your car already attached. You will simply wire your new radio the ROEM/NIS1 and plug it into the car. You will also need to remember to wire the amplifier remote turn-on out of your radio. It's all color coded though. |
thank broadfield... i really appriciate you for posting and taking your time out and type for me.. .and yes..it work now.. i did the right way ...Option c...and work perfectly... thank you...thread close..
I am new to this forum stuff. I have been a Z owner for about a year and I could really use some help. I have done a lot of research on this and I own a 1991 300zx TT with a bose system. I hooked up everything correctly (hopefully) to the harness (all the wires, speaker wires to the RCA preamp) but I don't use the radio so I didn't bother plugging in the two prong antenna because when I looked online for the adapter, there was weird one where the two prong split into the normal/common adapter and some other thing which I didn't understand. But all the cable are connected even the ground for the amp and turn on BUT my aftermarket kenwood will not turn on. Does the antenna have something to do with this? I don't understand why but when I plugged the original bose back in to see if I could figure the problem out and it would not turn on without the two prong antenna being plugged in. Kind of weird unless the antenna serves more than the purpose of being just an antenna. Or should I separately wire the power and ground directly to battery? Also the stock bose had a ground wire on the back harness and under it attached to the headunit, do I nee to use that as well? Thanks for all your help guys.
